Bigtreetech smart filament sensor
Same question - I just finished making all the cables for my new DUET 2 ethernet setup - and connected the Bigreetech smart filament sensor physically, but haven't found any info on setting up the sensor in Raprap properly....
Since the sensor should work in Marlin 2.0 pretty much seamlessly - maybe we can check in the source? Does anyone have any ideas?
Is this the product you try to connect? https://github.com/bigtreetech/smart-filament-detection-module/blob/master/manual/smart filament sensor module manual191205.pdf
It works also on 3.3V (good), has GND, power and signal wires, and the 'break interface' sounds as an on/off output. In Duet's terminology, this sounds a 'filament run-out sensor' (not to be confused with a 'filament monitor').
https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_filament-out_sensors
@zapta Thanks for the answer.
Yes, that is the product. I have already connected the wiring to the E0 stop properly (+3V, Signal, GND) - but I have seen on the other post (here) that another user has been having problems in setting it in firmware.... it's a pulse sensor it has a rotary encoder (I don't know if it's an optical or magnet one, haven't disassembled it completely). That is why I was asking if anyone had success in setting it up properly...
@omni, if it's a pulse generating sensor, does option #7 here work? https://duet3d.dozuki.com/Wiki/Gcode#Section_M591_Configure_filament_sensing
(you will also need to specify pulses per millimeter, the Duet input you are using, and the extruder it relates to)
I've tried it yesterday - but it seems that Duet is not recording any data from the sensor.I configured the sensor as following, just to log data when printing :
M591 D0 P7 C"^e0stop" L0.07853981634 R90:110 E3 S0
but it did not receive any data.
Any ideas on what I can try is highly appreciated.
Thanks again
@omni any luck? I have one of these on hand I use on my Marlin machines and would like to use it as well.
@eight_heads lemme answer before he gets online (he's not very active on forum ). it works on his board, the config does not need pullup and need much bigger values as it is low res
so something like
M591 D0 P7 C"e0stop" L7 R50:200 E15 S0
@arhi do you test it on your board?
I want to buy the same sensor you did. -
@phcella said in Bigtreetech smart filament sensor:
I want to buy the same sensor you did.I am not using btr smart filament sensor
@eight_heads I just used @arhi config and tested the BTT Smart Filament sensor on my Duet WIFI - Seems to be working perfectly!
@phcella I just tested, success!
Mine worked well for a while and then started to give false warnings and stops (under extrusion), and now it does not work at all. I guess that maybe the spring holding the wheel got loose and it's not rotating enough while the filament is passing, but haven't opened it yet to check....
@Stockerbot Thanks, I will buy one to test it.
