DuetLapse3
@stuartofmt its the other way round.
rr_model is replaced by machine/status in SBC situations -
OK - thx. It's not difficult but I will need some help testing.
@stuartofmt
i can provide a current 3.2 output from machine/status if needed.
i'm sure @PCR would do some testing for you -
That would be very helpful (much better than closing my eyes and imagining) - thanks!
{"boards":[{"bootloaderFileName":null,"canAddress":0,"directDisplay":null,"firmwareDate":"2021-01-05","firmwareFileName":"Duet3Firmware_Mini5plus.uf2","firmwareName":"RepRapFirmware for Duet 3 Mini 5\u002B","firmwareVersion":"3.2","iapFileNameSBC":"Duet3_SBCiap32_Mini5plus.bin","iapFileNameSD":"Duet3_SDiap32_Mini5plus.bin","maxHeaters":32,"maxMotors":7,"mcuTemp":{"current":-273.15,"min":-273.15,"max":-273.15},"name":"Duet 3 Mini 5\u002B","shortName":"Mini5plus","state":"unknown","supports12864":true,"supportsDirectDisplay":true,"uniqueId":"P2P4H-PA67A-G65J0-40TFU-L2D0Z-ZTS4L","v12":{"current":0,"min":0,"max":0},"vIn":{"current":12.3,"min":0,"max":12.3}}],"directories":{"filaments":"0:/filaments/","firmware":"0:/sys/","gCodes":"0:/gcodes/","macros":"0:/macros/","menu":"0:/menu/","scans":"0:/scans/","system":"0:/sys/","web":"0:/www/"},"fans":[{"actualValue":0,"blip":0.1,"frequency":0,"max":1,"min":0.1,"name":"","requestedValue":0,"rpm":-1,"thermostatic":{"heaters":[],"highTemperature":null,"lowTemperature":null}},{"actualValue":0,"blip":0.1,"frequency":0,"max":1,"min":0.1,"name":"","requestedValue":1,"rpm":-1,"thermostatic":{"heaters":[1],"highTemperature":45,"lowTemperature":45}}],"heat":{"bedHeaters":[0,-1],"chamberHeaters":[-1,-1],"coldExtrudeTemperature":160,"coldRetractTemperature":90,"heaters":[{"active":0,"current":15.4,"max":120,"min":-273.1,"model":{"deadTime":2.2,"enabled":true,"gain":114,"heatingRate":0.219,"inverted":false,"maxPwm":1,"pid":{"overridden":false,"p":1.5,"i":0.1,"d":2.2,"used":true},"standardVoltage":12.2,"timeConstant":520.5,"timeConstantFansOn":520.5},"monitors":[{"action":0,"condition":"tooHigh","limit":120},{"action":null,"condition":"disabled","limit":null},{"action":null,"condition":"disabled","limit":null}],"name":null,"sensor":0,"standby":0,"state":"off"},{"active":0,"current":15.9,"max":285,"min":-273.1,"model":{"deadTime":7,"enabled":true,"gain":407.9,"heatingRate":2.343,"inverted":false,"maxPwm":1,"pid":{"overridden":false,"p":0,"i":0,"d":0.2,"used":true},"standardVoltage":12.2,"timeConstant":174.1,"timeConstantFansOn":152.7},"monitors":[{"action":0,"condition":"tooHigh","limit":285},{"action":null,"condition":"disabled","limit":null},{"action":null,"condition":"disabled","limit":null}],"name":null,"sensor":1,"standby":0,"state":"active"}]},"httpEndpoints":[],"inputs":[{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"HTTP","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"Marlin","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"Telnet","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"File","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"Marlin","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"USB","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"Aux","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":true,"name":"Trigger","stackDepth":1,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"Queue","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"LCD","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"SBC","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"Daemon","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"Aux2","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"Autopause","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false}],"job":{"build":null,"duration":null,"file":{"filament":[],"fileName":null,"firstLayerHeight":0,"generatedBy":null,"height":0,"lastModified":null,"layerHeight":0,"numLayers":0,"printTime":null,"simulatedTime":null,"size":0,"thumbnails":[]},"filePosition":0,"firstLayerDuration":null,"lastDuration":0,"lastFileName":null,"lastFileAborted":false,"lastFileCancelled":false,"lastFileSimulated":false,"layer":null,"layerTime":null,"layers":[],"timesLeft":{"filament":null,"file":null,"layer":null},"warmUpDuration":null},"limits":{"axes":8,"axesPlusExtruders":8,"bedHeaters":2,"boards":5,"chamberHeaters":2,"drivers":14,"driversPerAxis":4,"extruders":5,"extrudersPerTool":5,"fans":16,"gpInPorts":16,"gpOutPorts":32,"heaters":32,"heatersPerTool":2,"monitorsPerHeater":3,"restorePoints":6,"sensors":56,"spindles":2,"tools":50,"trackedObjects":32,"triggers":16,"volumes":2,"workplaces":9,"zProbeProgramBytes":8,"zProbes":4},"messages":[],"move":{"axes":[{"acceleration":1000,"babystep":0,"current":1200,"drivers":["0.4"],"homed":false,"jerk":1000,"letter":"X","machinePosition":0,"max":270,"maxProbed":false,"microstepping":{"interpolated":true,"value":16},"min":0,"minProbed":false,"speed":6000,"stepsPerMm":100,"userPosition":0,"visible":true,"workplaceOffsets":[0,0,0,0,0,0,0,0,0]},{"acceleration":1000,"babystep":0,"current":1200,"drivers":["0.3"],"homed":false,"jerk":1000,"letter":"Y","machinePosition":0,"max":260,"maxProbed":false,"microstepping":{"interpolated":true,"value":16},"min":0,"minProbed":false,"speed":6000,"stepsPerMm":100,"userPosition":0,"visible":true,"workplaceOffsets":[0,0,0,0,0,0,0,0,0]},{"acceleration":200,"babystep":0,"current":1200,"drivers":["0.1","0.2"],"homed":false,"jerk":200,"letter":"Z","machinePosition":0,"max":350,"maxProbed":false,"microstepping":{"interpolated":true,"value":16},"min":0,"minProbed":false,"speed":300,"stepsPerMm":400,"userPosition":0,"visible":true,"workplaceOffsets":[0,0,0,0,0,0,0,0,0]}],"calibration":{"final":{"deviation":0,"mean":0},"initial":{"deviation":0,"mean":0},"numFactors":0},"compensation":{"fadeHeight":null,"file":null,"meshDeviation":null,"probeGrid":{"xMin":15,"xMax":230,"xSpacing":20,"yMin":15,"yMax":230,"ySpacing":20,"radius":-1},"skew":{"compensateXY":true,"tanXY":0,"tanXZ":0,"tanYZ":0},"type":"none"},"currentMove":{"acceleration":0,"deceleration":0,"laserPwm":null,"requestedSpeed":0,"topSpeed":0},"daa":{"enabled":false,"minimumAcceleration":10,"period":0},"extruders":[{"acceleration":250,"current":1000,"driver":"0.0","filament":"","factor":1,"jerk":120,"microstepping":{"interpolated":true,"value":16},"nonlinear":{"a":0,"b":0,"upperLimit":0.2},"position":0,"pressureAdvance":0,"rawPosition":0,"speed":1200,"stepsPerMm":837}],"idle":{"timeout":30,"factor":0.3},"kinematics":{"forwardMatrix":[[1,0,0],[0,1,0],[0,0,1]],"inverseMatrix":[[1,0,0],[0,1,0],[0,0,1]],"tiltCorrection":{"correctionFactor":1,"lastCorrections":[0,0],"maxCorrection":10,"screwPitch":0.5,"screwX":[-130,400],"screwY":[150,150]},"name":"cartesian"},"printingAcceleration":10000,"speedFactor":1,"travelAcceleration":10000,"virtualEPos":0,"workplaceNumber":0,"workspaceNumber":1},"network":{"corsSite":null,"hostname":"duet3","interfaces":[{"activeProtocols":[],"actualIP":"192.168.1.31","configuredIP":"192.168.1.31","firmwareVersion":null,"gateway":"192.168.1.1","mac":"B8:27:EB:C9:9C:1A","numReconnects":null,"signal":null,"speed":null,"subnet":"255.255.255.0","type":"wifi"}],"name":"duet3"},"plugins":[{"dwcFiles":["GCodeViewer.10bd9549.js","GCodeViewer.88004336.css"],"sbcFiles":[],"rrfFiles":[],"pid":-1,"name":"GCodeViewer","author":"Juan Rosario","version":"0.11.1","license":"LGPL-3.0-or-later","sourceRepository":null,"dwcVersion":"3.2.0-beta4","dwcDependencies":[],"dwcWebpackChunk":"GCodeViewer","sbcRequired":false,"sbcDsfVersion":null,"sbcData":{},"sbcExecutable":null,"sbcExecutableArguments":null,"sbcOutputRedirected":true,"sbcPermissions":[],"sbcPackageDependencies":[],"sbcPluginDependencies":[],"rrfVersion":null}],"scanner":{"progress":0,"status":"D"},"sensors":{"analog":[{"lastReading":15.4,"name":"","type":"thermistor"},{"lastReading":15.9,"name":"","type":"thermistor"}],"endstops":[{"triggered":false,"type":"inputPin","probeNumber":null},{"triggered":false,"type":"inputPin","probeNumber":null},null],"filamentMonitors":[],"gpIn":[],"probes":[{"calibrationTemperature":25,"deployedByUser":false,"disablesHeaters":false,"diveHeight":2,"lastStopHeight":0,"maxProbeCount":5,"offsets":[-27.3,3.5],"recoveryTime":0,"speed":2,"temperatureCoefficient":0,"temperatureCoefficients":[0,0],"threshold":1000,"tolerance":0.02,"travelSpeed":333.3,"triggerHeight":3.553,"type":1,"value":[671]}]},"spindles":[{"active":0,"current":0,"frequency":0,"min":60,"max":10000,"tool":-1},{"active":0,"current":0,"frequency":0,"min":60,"max":10000,"tool":-1}],"state":{"atxPower":null,"beep":null,"currentTool":0,"displayMessage":"","dsfVersion":"3.2.0","gpOut":[{"pwm":0}],"laserPwm":null,"logFile":null,"logLevel":"off","messageBox":null,"machineMode":"FFF","msUpTime":503,"nextTool":0,"powerFailScript":"","previousTool":-1,"restorePoints":[{"coords":[0,0,0],"extruderPos":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[0,0],"toolNumber":-1},{"coords":[0,0,0],"extruderPos":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[0,0],"toolNumber":-1},{"coords":[0,0,0],"extruderPos":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[0,0],"toolNumber":-1},{"coords":[0,0,0],"extruderPos":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[0,0],"toolNumber":-1},{"coords":[0,0,0],"extruderPos":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[0,0],"toolNumber":-1},{"coords":[0,0,0],"extruderPos":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[0,0],"toolNumber":-1}],"status":"idle","time":"2021-01-14T17:44:25","upTime":363424},"tools":[{"active":[0],"axes":[[0],[1]],"extruders":[0],"fans":[0],"filamentExtruder":0,"heaters":[1],"mix":[1],"name":"","number":0,"offsets":[0,0,0],"offsetsProbed":0,"retraction":{"extraRestart":0,"length":5,"speed":40,"unretractSpeed":40,"zHop":0.5},"standby":[0],"state":"active"}],"userSessions":[],"userVariables":[],"volumes":[{"capacity":29077254144,"freeSpace":20587024384,"mounted":true,"name":null,"openFiles":null,"path":"/","speed":null},{"capacity":2143281152,"freeSpace":2028986368,"mounted":true,"name":null,"openFiles":null,"path":"/boot","speed":null}]}
Could someone please try this? It's a test script for the SBC calls. It's read only with the exception of a M117 'Test of SBC' which should show up in DWC.
Once its placed in a directory permissions will need to be changed.
chmod +x ./SBCTEST.py
it can then be run with the following command
python3 ./SBCTEST.py -duet <ipaddress of your SBC printer>
with a bit of luck it will report success, in any case - if the resultant SBCTEST.log file can be posted back, that would be a great help.
I've tested it on my non SBC duet - there may be some syntax errors in the unexercised code - but I hope not
If there are then a screen shot would be helpful. -
Can do it tomorrow! Thank you
@stuartofmt said in DuetLapse3:
localhost Determine API Version localhost Testing: rr_model at address localhost localhost http://localhost/rr_model?key=boards localhost localhost Testing: /machine/system at address localhost localhost http://localhost/machine/status localhost localhost API model is: machine Version is: 3 localhost Status is :idle localhost Layer is :0 Traceback (most recent call last): File "./SBCTEST.py", line 147, in <module> logger.info('Send Gcode result: '+sendDuetGcode(apiModel, 'M117 Test of SBC')) File "./SBCTEST.py", line 122, in sendDuetGcode r = requests.get.post(URL, data=command) AttributeError: 'function' object has no attribute 'post'
Nothing is displayed on DWC
192.168.140.126 Determine API Version 192.168.140.126 Testing: rr_model at address 192.168.140.126 192.168.140.126 http://192.168.140.126/rr_model?key=boards 192.168.140.126 192.168.140.126 Testing: /machine/system at address 192.168.140.126 192.168.140.126 http://192.168.140.126/machine/status 192.168.140.126 192.168.140.126 API model is: machine Version is: 3 192.168.140.126 Status is :processing 192.168.140.126 Layer is :0 --- Logging error --- Traceback (most recent call last): File "/usr/lib/python3.7/logging/__init__.py", line 1034, in emit msg = self.format(record) File "/usr/lib/python3.7/logging/__init__.py", line 880, in format return fmt.format(record) File "/usr/lib/python3.7/logging/__init__.py", line 619, in format record.message = record.getMessage() File "/usr/lib/python3.7/logging/__init__.py", line 380, in getMessage msg = msg % self.args TypeError: not all arguments converted during string formatting Call stack: File "./sbctest.py", line 147, in <module> logger.info('Send Gcode result: '+sendDuetGcode(apiModel, 'M117 Test of SBC')) File "./sbctest.py", line 127, in sendDuetGcode logger.info("gCode command return code = ",r.status_code) Message: 'gCode command return code = ' Arguments: (405,) --- Logging error --- Traceback (most recent call last): File "/usr/lib/python3.7/logging/__init__.py", line 1034, in emit msg = self.format(record) File "/usr/lib/python3.7/logging/__init__.py", line 880, in format return fmt.format(record) File "/usr/lib/python3.7/logging/__init__.py", line 619, in format record.message = record.getMessage() File "/usr/lib/python3.7/logging/__init__.py", line 380, in getMessage msg = msg % self.args TypeError: not all arguments converted during string formatting Call stack: File "./sbctest.py", line 147, in <module> logger.info('Send Gcode result: '+sendDuetGcode(apiModel, 'M117 Test of SBC')) File "./sbctest.py", line 127, in sendDuetGcode logger.info("gCode command return code = ",r.status_code) Message: 'gCode command return code = ' Arguments: (405,) 192.168.140.126 Method Not Allowed Traceback (most recent call last): File "./sbctest.py", line 147, in <module> logger.info('Send Gcode result: '+sendDuetGcode(apiModel, 'M117 Test of SBC')) TypeError: can only concatenate str (not "int") to str
Thanks - there was a silly formatting error (now fixed) but underlying that it looks like there was an http 405 error returned.
I've added a two more version of the send gcode function to try - hopefully one of them works. Unfortunately the documentation and other examples (which purport to work) are somewhat vague on this aspect ....
ALSO - if you are running RRF3.2 the default behavior for CORS seems to have changed. With another program I am using (DueUI) - I had to add the following to config.sys (up front in the network section) - after the upgrade. BUT DuetLapse was unaffected. It MAY be different on SBC.
I'd suggest first trying "as is" but if this script still does not work with one of the methods (depending on what the errors are) - the CORS thing may need to be looked into.
M586 C"*" ;enable CORS
New Test Script is here
Awesome Stuart, thanks for carrying on Danal's work
Looks well documented too, I'll give it a shot over the weekend.
Very neat of you to handle issues outside of your own setup too
Do you think in it's current state this could realistically be implemented as a plugin in DWC for a possible GUI?
Thanks. As a plugin ? hmmm . I'll have to see what that means / entails. Let me put that as a priority 2 for right now.
Priority 1 is getting SSB working and tidying up some of the logic / behavior surrounding pauses. I did not test that aspect much and its somewhat ambiguous - so stay tuned ...
192.168.1.31 Determine API Version 192.168.1.31 Testing: rr_model at address 192.168.1.31 192.168.1.31 http://192.168.1.31/rr_model?key=boards 192.168.1.31 192.168.1.31 Testing: /machine/system at address 192.168.1.31 192.168.1.31 http://192.168.1.31/machine/status 192.168.1.31 192.168.1.31 API model is: SBC Version is: 3 192.168.1.31 Status is :idle 192.168.1.31 Layer is :0 192.168.1.31 ***Testing V0*** 405 Method Not Allowed 192.168.1.31 gCode command return code = 405 192.168.1.31 Method Not Allowed 192.168.1.31 Send Gcode result: 405 192.168.1.31 ***Testing V1*** 200 OK 192.168.1.31 Send Gcode result: 0 192.168.1.31 ***Testing V2*** 404 Not Found 192.168.1.31 gCode command return code = 404 192.168.1.31 Not Found 192.168.1.31 Send Gcode result: 404
OK! Looks like V1 worked!! So you should have got a message on DWC saying "Test of SBC"
Did you see that ?
@stuartofmt
No, nothing displayed on DWC -
Ok - I'm going to have to get some help. The code I have seen elsewhere (including Danal's) does not work (or I've done something stupid). The one that reports success - does not seem to send the gcode .... go figure .....
So - this should work for SBC -- but not for using the pause capability (that's the only thing that sends gcodes).
Appreciate it if you could test before I update githubHmm - wont let me upload the file to here. I'll update on github - if you would not mind downloading from there.
Ok it looks like we are getting close ( thanks to an "anonymous" tip in another thread )
Can you try this please. V3 is the latest (and hopefully correct) form.
In order to better handle pause situations - I need to access Duet to get a previously unused set of parameters. I'll post a new test script tomorrow. If successful - then SBC should be fully supported. Stay tuned and thanks for the help.
@stuartofmt i will have acces to my SBC printer tomorrow
