Please: need to update DWC
@Veti great. Worked first shot. Thanks again.
@Veti I unfortunately need to change my reply to: "It worked once but not again". Anything I can try. I cannot even access it from my phone or tablet. Page remains empty. I don't get an error message ... only empty page.
The wifi seems ok. I could start a single layer square which is printing now. Page remains empty.
Any other advice will be most welcome. At the moment I am stuck with an empty page.
If needed, I can access the printer through a USB cable with my Laptop. -
what url are you accessing?
can you try in incognito mode?
@Veti I'm using the printer's IP address. I can successfully ping it and it is also listed as a connected device on router UI.
I tried with Edge, Firefox & Chrome, normal and private/incognito mode and in all instances just a blank page.
I have also switch off and back on the printer a couple of times.
can you type in the url ip/reprap.htm
@Veti How did you know that? You're a genius. Thanks for sticking with me. I don't mind having it like this, but what did not happen or happen? I want to learn.
It doesn't look like it installed the file:
Firmware Version: 2.05.1 (2020-02-09b1)
WiFi Server Version: 1.23
Web Interface Version: 1.22.6 -
no the reprap.htm will go back to version 1
can you try the release from here
https://github.com/Duet3D/RepRapFirmware/releases/tag/2.05.1 -
@Veti
Ok, thanks. I have just loaded the file again under ip/reprap.htmNothing seemed different. I tried again to load the page but only with IP. And it refreshed to what seems to be the updated DWC.
It looks a whole lot different and will have to learn the new layout ... but I like it.Thank you so much again for your help. Much appreciated.
It says:
Duet Web Control 2.0.7I'm so happy.
@deonholt said in Please: need to update DWC:
there will not be an update to version 2
so you might consider going to rrf3, but that is a bit more as the config changes.
@Veti
Yes, I have learned that. I am not comfortable doing it myself at this stage. Will do it later some time.Thanks again. You have been a great help. The think I like for now the most is that I can change the baby-steps' increments.
