Duet2 WiFi Firmware on Raise 3d E2 ?
then does not flash the return value
@Proschi78
btw when you says your printer does not work, what do you mean?there are configuration changes required for going from 2.0 to 3.0
@Veti the printer no longer starts with firmware 3.0
it does. you posted the m122 output.
@Veti (>>) === Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0 running on Duet WiFi 1.02 or later<LF>Board ID: 08DGM-9T6BU-FG3SS-6J9FD-3S46R-TVSHD<LF>Used output buffers: 1 of 24 (3 max)<LF>=== RTOS ===<LF>Static ram: 30516<LF>Dynamic ram: 91744 of which 68 recycled<LF>Exception stack ram used: 256<LF>Never used ram: 8488<LF>Tasks: NETWORK(ready,1888) HEAT(blocked,1476) MAIN(running,3764) IDLE(ready,156)<LF>Owned mutexes:<LF>=== Platform ===<LF>Last reset 00:00:15 ago, cause: power up<LF>Last software reset time unknown, reason: User, spinning module GCodes, available RAM 8440 bytes (slot 1)<LF>Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00433000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d<LF>Error status: 0<LF>Free file entries: 10<LF>SD card 0 detected, interface speed: 20.0MBytes/sec<LF>SD card longest block write time: 0.0ms, max retries 0<LF>MCU temperature: min 26.0, current 28.1, max 28.4<LF>Supply voltage: min 1.4, current 1.5, max 1.6, under voltage events: 0, over voltage events: 0, power good: no<LF>Dr[Warning: Maximal number of bytes per line exceeded! Check the EOL (end-of-line) settings or increase the limit in the advanced terminal settings.]
yes so the printer starts.
@Proschi78 said in
this is befor updatingDuet2 WiFi Firmware on Raise 3d E2 ?:
(>>) === Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 or later<LF>Board ID: 08DLM-996RU-N8PS4-7J1D8-3SJ6N-1B9BR<LF>Used output buffers: 1 of 20 (1 max)<LF>=== RTOS ===<LF>Static ram: 25536<LF>Dynamic ram: 99000 of which 0 recycled<LF>Exception stack ram used: 256<LF>Never used ram: 6280<LF>Tasks: HEAT(blocked,1232) MAIN(running,3828) IDLE(ready,200)<LF>Owned mutexes:<LF>=== Platform ===<LF>Last reset 00:00:40 ago, cause: power up<LF>Last software reset time unknown, reason: User, spinning module GCodes, available RAM 6224 bytes (slot 0)<LF>Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d<LF>Error status: 0<LF>Free file entries: 10<LF>SD card 0 detected, interface speed: 20.0MBytes/sec<LF>SD card longest block write time: 0.0ms, max retries 0<LF>MCU temperature: min 18.7, current 23.2, max 23.4<LF>Supply voltage: min 0.0, current 0.6, max 0.9, under voltage events: 0, over voltage events: 0, power good: no<LF>Driver 0: ok, SG[Warning: Maximal number of bytes per line exceeded! Check the EOL (end-of-line) settings or increase the limit in the advanced terminal settings.]
yes, but my statement was, the firmware was updated to 3.0.
there are config changes you need to do as the rrf2 config does not work with rrf3.
without those changes you wont be able to move anything.
I'll keep trying tomorrow, thank you
the main problem now is that the printer doesn't start anymore.
by start I mean that the display no longer starts up in the menu.
it doesn't finish loading -
@Proschi78 i guess you need to go back to 2.02 then
@jay_s_uk that's exactly what I tried.
it just didn't work out.
the board stays at 3.0 -
@Proschi78
that might be a price to pay for running the original firmware on the raise 3d -
@Veti but unfortunately he no longer plays the original firmware on the board via the printer
not sure what you mean
@Veti https://support.raise3d.com/E2/how-to-update-the-motion-controller-firmware-20-1143.html
The printer does not do the firmware update because the board is flashed to 3.0
@Proschi78
yes but the firmware updated to 3.0. that is what you wanted to do in the first place.
a lcd screen is not necessary for the operation of a duet. -
@Veti said in Duet2 WiFi Firmware on Raise 3d E2 ?:
a lcd screen is not necessary for the operation of a duet.in my case it does
the WiFi module sits on the display controller -
@Proschi78 said in Duet2 WiFi Firmware on Raise 3d E2 ?:
in my case it does
the WiFi module sits on the display controllerwell you might want to change the eol and line settings in yat so that you can see the actual status of the wifi module.
