ToolBoard: 2 wires fan, heater fault and how to extrude ?
@Pseud3mys said in ToolBoard: 2 wires fan, heater fault and how to extrude ?:
Error: Failed to switch off remote heater 2: Board 122 does not have heater 2
do you still get this error message?
@Veti no, when I update it now it just put "2000°C" and offline on the web site but he is still connected with the CAN bus
post the output of
M122 B121
and
M122 B122 -
you power down the system after the firmware update?
also power the normal M122 output
@Veti yes, what is the M122 output ?
i meant provide the m122 output
@Veti said in ToolBoard: 2 wires fan, heater fault and how to extrude ?:
it was not this ?
no just send M122. that will provide the output for the duet 3
@Veti ah okay, the popup say "response too long, see console"
02/12/2020 à 19:08:20 M122
RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (standalone mode)
Board ID: 08DJM-956BA-NA3TJ-6J1D2-3SD6M-9B9LT
Used output buffers: 1 of 40 (23 max)
Static ram: 154604
Dynamic ram: 162588 of which 36 recycled
Exception stack ram used: 224
Never used ram: 75764
Tasks: NETWORK(ready,292) ETHERNET(blocked,436) HEAT(blocked,1248) CanReceiv(suspended,3404) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,204) MAIN(running,4520) IDLE(ready,76)
Owned mutexes: LwipCore(NETWORK)
Last reset 00:00:54 ago, cause: software
Last software reset at 2020-12-02 19:07, reason: User, spinning module GCodes, available RAM 75728 bytes (slot 2)
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
Error status: 0
MCU temperature: min 36.6, current 37.0, max 37.6
Supply voltage: min 12.2, current 12.3, max 12.3, under voltage events: 0, over voltage events: 0, power good: yes
12V rail voltage: min 11.4, current 11.4, max 11.5, under voltage events: 0
Driver 0: standstill, reads 6703, writes 0 timeouts 0, SG min/max not available
Driver 1: standstill, reads 6704, writes 0 timeouts 0, SG min/max not available
Driver 2: standstill, reads 6702, writes 0 timeouts 0, SG min/max not available
Driver 3: standstill, reads 6702, writes 0 timeouts 0, SG min/max not available
Driver 4: standstill, reads 6702, writes 0 timeouts 0, SG min/max not available
Driver 5: standstill, reads 6701, writes 0 timeouts 0, SG min/max not available
Date/time: 2020-12-02 19:08:18
Slowest loop: 6.33ms; fastest: 0.22ms
=== Storage ===
Free file entries: 10
SD card longest read time 2.2ms, write time 0.0ms, max retries 0
=== MainDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 5.59ms; fastest: 0.03ms
HTTP sessions: 1 of 8- Ethernet -
State: active
Error counts: 0 0 0 0 0
=== CAN ===
Messages sent 59, longest wait 0ms for type 0
=== Linux interface ===
State: 0, failed transfers: 0
Last transfer: 54276ms ago
RX/TX seq numbers: 0/1
SPI underruns 0, overruns 0
Number of disconnects: 0
Buffer RX/TX: 0/0-0
- Ethernet -
hmm can communication seems to be working.
can you update to the latest beta as the diagnostic has been improved.
@Veti can we update duet with M997 ?
I have:
Error: M997: In-application programming binary "Duet3_SDiap_MB6HC.bin" not found
but there is not this file in the repository ? (git hub ) -
find that file here
https://github.com/Duet3D/RepRapFirmware/releases/tag/3.0 -
This post is deleted! -
M122 B121 command (for the tool board):
02/12/2020 à 19:29:11 M122 B121
Diagnostics for board 121:
Duet TOOL1LC firmware version 3.2-beta4 (2020-11-26)
Bootloader ID: not available
Never used RAM 4700, free system stack 96 words
HEAT 42 CanAsync 88 CanRecv 82 TMC 48 MAIN 341 AIN 64
Last reset 00:03:22 ago, cause: software
Last software reset data not availableDriver 0: position 0, 80.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 35710, writes 9, timeouts 0, DMA errors 0
Moves scheduled 0, completed 0, in progress 0, hiccups 0
No step interrupt scheduled
VIN: 12.2V
MCU temperature: min 22.6C, current 25.2C, max 25.2C
Ticks since heat task active 46, ADC conversions started 202540, completed 202539, timed out 0
Last sensors broadcast 0x00000000 found 0 50 ticks ago, loop time 0
CAN messages queued 16, send timeouts 0, received 1906, lost 0, free buffers 36 -
and for the mainboard:
02/12/2020 à 19:34:16 M122
RepRapFirmware for Duet 3 MB6HC version 3.2-beta4 running on Duet 3 MB6HC v1.01 or later (standalone mode)
Used output buffers: 1 of 40 (12 max)
Static ram: 123212
Dynamic ram: 168576 of which 752 recycled
Never used RAM 99652, free system stack 200 words
Tasks: NETWORK(ready,171) ETHERNET(blocked,110) HEAT(blocked,317) CanReceiv(blocked,852) CanSender(blocked,371) CanClock(blocked,356) TMC(blocked,54) MAIN(running,1127) IDLE(ready,19)
Owned mutexes:
Last reset 00:00:46 ago, cause: software
Last software reset details not available
Error status: 0x00
MCU temperature: min 37.9, current 39.0, max 39.3
Supply voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 0, standstill, reads 35416, writes 14 timeouts 0, SG min/max 0/0
Driver 1: position 0, standstill, reads 35417, writes 14 timeouts 0, SG min/max 0/0
Driver 2: position 0, standstill, reads 35418, writes 14 timeouts 0, SG min/max 0/0
Driver 3: position 0, standstill, reads 35422, writes 11 timeouts 0, SG min/max 0/0
Driver 4: position 0, standstill, reads 35423, writes 11 timeouts 0, SG min/max 0/0
Driver 5: position 0, standstill, reads 35424, writes 11 timeouts 0, SG min/max 0/0
Date/time: 2020-12-02 19:34:15
Slowest loop: 5.81ms; fastest: 0.15ms
=== Storage ===
SD card longest read time 2.4ms, write time 0.0ms, max retries 0
=== MainDDARing ===
Scheduled moves 0, completed moves 0, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
=== AuxDDARing ===
Segments left: 0
=== Network ===
Slowest loop: 15.69ms; fastest: 0.03ms
State: active
=== CAN ===
Messages queued 171, send timeouts 0, received 896, lost 0, longest wait 2ms for reply type 6031, free buffers 47
- Ethernet -
duet 3 is also updated?
any info on the heating now?
@Veti still no error, but now it show "fault" 1 second and after the web interface lost the board (2000°C and offline), but the M115 command still return that the can bus is connected
02/12/2020 à 19:42:27 M122 B122
Diagnostics for board 122:
HEAT 42 CanAsync 88 CanRecv 82 TMC 48 MAIN 341 AIN 70
Last reset 00:01:20 ago, cause: software
Last software reset at 2020-12-02 19:41, reason: HardFault, available RAM 4360, slot 0
Software reset code 0x0060 ICSR 0x00000003 SP 0x200011c0 Task
Stack: 20001014 00000011 0001d3e3 00000000 20000928 0001757d 000184fe 01000000 000202a8 000203a2 20001210 200032d8 00000020 00017d11 20004668 00000000 20001300 000086e5 000202a8 20004678 000203a2 4200af00 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5
Driver 0: position 0, 80.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 40161, writes 9, timeouts 0, DMA errors 0
VIN: 12.3V
MCU temperature: min 30.8C, current 30.8C, max 30.9C
Ticks since heat task active 127, ADC conversions started 80370, completed 80369, timed out 0
Last sensors broadcast 0x00000000 found 0 131 ticks ago, loop time 0
CAN messages queued 22, send timeouts 0, received 732, lost 0, free buffers 36it seem than the borad restart..
