Newbie: New Install on Ender 5 Plus---Willing to PAY$$$
Recycling is tomorrow. Is the printer recyclable?
@Veti Dunno
E5Plus
Send code...
Status
Idle
Mode: FFF
Tool Position
X
0.0
Y
0.0
Z
0.00
Extruder Drives
Drive 0
0.0
Speeds
Requested Speed
0 mm/s
Top Speed
0 mm/s
Sensors
Vin
24.3 V
MCU Temperature
25.9 C
Z-Probe
0
Tools
Extra
Control All
Tool Heater Current Active Standby
Tool 0
T0 - Load Filament Heater 1
off 22.4 C
0
0
Bed Heater 0
off 21.9 C
0
0
Temperature Chart
Macros Directory
0:/macros/01-Test_IR_PD_Homing
; Test Routine for Duet WiFi and Ethernet June 2018 - Check IR Probe, PanelDue and endstops;Start logging
M929 P"test1log.txt" S1M117 CHECK IR PROBE & PANELDUE THEN PRESS X ENDSTOP.
M577 X S2 ; wait for endstop to trigger
M577 X S0 ; wait for endstop release;----setup motors for test----
M906 X2000 Y2000 Z2000 E2000:2000 I100 ;set all motors to 2A with no idle current reduction;----homing line (tests endstops)----
M117 PRESS ALL THREE ENDSTOPS TO END HOMING
G91 ; use relative positioning
G1 S1 X3200 Y3200 Z3200 F9000 ; move XYZ motors, stopping when endstops are triggered
;----end homing lines----M117 GO ON TO TEST 02
The endless moving happens when I press home all and each axis independently
@shatty
please dont use that macro, its not for your printer -
use M119
https://duet3d.dozuki.com/Wiki/Gcode#Section_M119_Get_Endstop_Status
to manually test your endstops.
if you can not get them to trigger, there is a problem with your wiring.
@Veti I tested endstops already under settings and machine specific. X and Y work
G1 X-1.3000000000000007 Y1 F6000 ; go to first bed probe point and home Z
replace that with
G1 X50 Y50 F600
when exactly does it try to move past the endstops?
during the first move? -
@Veti Yes. I tried that setting and no good. Its random in which direction it goes to home and it just slams at the end of each axis.
; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Nov 15 2020 03:22:47 GMT-0500 (Eastern Standard Time)
G91 ; relative positioning
G1 H1 X-355 Y-355 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-355 Y-355 F360 ; move slowly to X and Y axis endstops once more (second pass)
G90 ; absolute positioning
G1 X50 Y50 F600 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioning; Configuration file for Duet WiFi (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Nov 15 2020 03:22:47 GMT-0500 (Eastern Standard Time); General preferences
M550 P"E5Plus" ; set printer name; Network
M551 P"xxxx" ; set password
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P2 S0 ; physical drive 2 goes backwards
M92 X80.00 Y80.00 Z800.00 E412.60 ; set steps per mm
M566 X1200.00 Y1200.00 Z60.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
M203 X9000.00 Y9000.00 Z1200.00 E6000.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z1400 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
M208 X350 Y350 Z400 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F600 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X16.3 Y14 Z1.7 ; set Z probe trigger value, offset and trigger height
M557 X15:190 Y15:190 S20 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
M143 H0 S110 ; set temperature limit for heater 0 to 110C
M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
M143 H1 S280 ; 280 deg max on hot end; Fans
M106 P0 S1 H1 ; set fan 0 value. Thermostatic control is turned off
M575 P1 S1 B57600 ; enable support for PanelDue -
@shatty said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
i have never heard of this happening.
let me get this straight.
you home your printer. it moves to the right?
you restart the printer it moves to the left?post the output of M119 when no endstop is pressed.
post the output of M119 when only the enstop for the x axis is pressed -
@Veti
When I turn it on, nothing moves unless i press the home button. There is no telling which direction it will go if i center the extruder in the middle of the area. Where am I supposed to set the hotend before I turn on the printer? -
@shatty
please test the stepper motor direction using this
https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Checking_connected_stepper_motorsreport for x y and z
Heres a video of what it does....
https://drive.google.com/file/d/1IeBbFe_YLu9XSz0GbuNmigxwDfcq57Ay/view?usp=sharing
please do the testing from the webui to rule out a bad touch screen connection.
btw what is that strange sound at the start of the homing?
@Veti said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
TS is fine.
Anyways....hitting any positive value will move each toward the endstop switch...The Z is not right..Looks like they are fighting each other
The Z axis motors are fighting each other.
that would indicate that your motors are turning in the wrong direction.
@Veti
OK Let me fix that. -
that means on of your motors is wired in the opposite direction
