DWC Z - Axis Movement off by Factor 10
@BoA Standard M8 Spindles
the movement sections is in your config twice
M92 X160.00 Y160.00 Z2560.00 E837.02 ; set steps per mm
this line overwrites the first line for example.I used Standard M8 Spindles with I believe 1.25 Pitch
those are not standard. you really need to know
post the link the the product that you bought. -
@Frederik said in DWC Z - Axis Movement off by Factor 10:
M8 Spindles have not been used in 3d printers for years because of bad results.
do you mean tr8 lead screw?
@Veti It was a complete Kit from Ratrig. There were no specifications other than M8 400mm
I will ask the manufacturer -
@Frederik Make a picture. will be faster.
according to the BOM:
8mm Metric ACME Lead Screw
@Frederik If this is Tr8x8 with 1.9deg stepper and 16microsteps it should be 400steps/mm
Also seems movement parameters section is doubled for some reason.
thats a 4 start tr8 leadscrew
it has an 8mm pitch
@Veti So as I wrote, 1.9deg, 16 microsteps, 8mm pitch - 400steps/mm. Not ~4000 or 2560.
And... what kind of extruder You have that E steps/mm are so.. not a round number?
thanks a lot, i will try the new values
@Frederik And cleanup You config. Seems
M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X160.00 Y160.00 Z2560.00 E837.02 ; set steps per mm M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X12000.00 Y12000.00 Z1800.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z30.00 E250.00 ; set accelerations (mm/s^2) M906 X1800 Y1800 Z1000 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X400 Y400 Z400 S0 ; set axis maxima ; Endstops M574 X2 S1 P"!io1.in" ; configure active-high endstop for high end on X via pin !io1.in M574 Y1 S1 P"!io0.in" ; configure active-high endstop for low end on Y via pin !io0.in M574 Z1 S2 ; configure Z-probe endstop for low end on Z
is duplicated
MY other question is about the LAser FIlament Sensor:
I only Found the following Line in the dozuki for RRF 3.x
M591 D0 P5 C"e0_stop" R40:120 E3.0 S0 ; Duet3D laser sensor for extruder drive 0, connected to endstop input 3 (E0), tolerance 40 to 120%, 3mm comparison length, disabled
would this work on my duet 3 (connected to io3)
M950 J3 C"!^io3.in" ; Input 3, inverted, pullup enabled
M591 D0 P5 C"io3.in" R40:120 E3.0 S1 ; Duet3D laser sensor for extruder drive 0, connected to IO 3,
tolerance 40 to 120%, 3mm comparison length, enabled -
@BoA oh, i see, thats a copy and paste error.... in my config its only once
I would remove this one.
@Frederik Should be fine. But I am guessing when filament monitoring shows some problems pause.g is executed to pause the print.
You can check sensor status by M591 D0
@BoA my extruder Setup:
Original Bondtech BMG with a E3d Volcano with 0.4 mm micro swiss nozzle and titan heatbreak. 40W Heater and Thermistor 100K
0.9° Pancake Stepperbedheater: 220V AC1.2 kW Keenovo Silicone Pad 400x400
@BoA said in DWC Z - Axis Movement off by Factor 10:
M591 D0
Response: Extruder 0 has no Filament Sensor
@Frederik BMG with 0.9 stepper + 16 microsteps should have 830steps/mm
