HOMES fine, CRASHES when starting print
@gloomyandy m122
RepRapFirmware for LPC176x based Boards (biquskr_1.4) version 3.1.1-14 running on LPC176x at 120Mhz
Used output buffers: 1 of 16 (10 max)
Static ram: 4468
Dynamic Memory (RTOS Heap 5): 1704 free, 1680 never used
Exception stack ram used: 408
Never used ram: 276
Tasks: HEAT(blocked,1372) MAIN(running,1840) IDLE(ready,84)
Owned mutexes:
Last reset 00:01:53 ago, cause: [power up]
LPC Flash Slot[66]:
Last software reset at 2020-11-15 11:49, reason: User, spinning module LinuxInterface, available RAM 252 bytes (slot 0)
Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0042a000 BFAR 0xe000ed38 SP 0x10000018 Task MAIN
Stack: 00000004 100010d0 2007e1e0 00000001 000462c7 00000004 10000d40 2007e1e0 2007d1dc 00000004
Stack: 00040205 80000000 00000000 00000000 2009c020 00000001 00040caf 00040d80 41000000 10003f68
Stack: 00000000 00000000 10003048
Error status: 0
Driver 0: standstill, SG min/max 0/388, error r/w 0/0, ifcnt 16, cnt r/w 7389/16, timeout 0, failedOp 0xff
Driver 1: standstill, SG min/max 0/398, error r/w 0/0, ifcnt 16, cnt r/w 7389/16, timeout 0, failedOp 0xff
Driver 2: standstill, SG min/max 0/126, error r/w 0/0, ifcnt 16, cnt r/w 7389/16, timeout 0, failedOp 0xff
Driver 3: standstill, SG min/max 0/118, error r/w 0/0, ifcnt 16, cnt r/w 7389/16, timeout 0, failedOp 0xff
Driver 4: standstill, SG min/max 0/0, error r/w 0/0, ifcnt 14, cnt r/w 7390/14, timeout 0, failedOp 0xff
Date/time: 2020-11-15 11:42:47
Slowest loop: 66.69ms; fastest: 0.30ms
Watchdog timer: 7492301/7500000
Step timer: target 102676553 count 113431450 delta -10754897 late 0
USBSerial connected 0
ADC not ready 0 ADC error threshold 10 ADC Init 1
Ints: 45452; Calls 136268; fast: 2uS; slow 20uS adj 0 bad 0 big delta 0
PWM Channels
state 0 next 55863 on 120000(0) off 120000(0) pin 2.5
state 1 next 55863 on 60000(1) off 60000(1) pin 2.3
state 2 next 55863 on 60000(0) off 60000(0) pin 2.7
state 3 next 55863 on 120000(0) off 120000(0) pin 2.4
Delta 55863 Start 0 End 4
Hiccups: 0, FreeDm: 100, MinFreeDm: 98, MaxWait: 77441ms
=== DDARing ===
Scheduled moves: 8, completed moves: 8, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
Bed heaters = 0, chamberHeaters = -1
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
HTTP* is ready with "M122" in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon* is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty.
=== Linux interface ===
State: 0, failed transfers: 0
Last transfer: 12ms ago
RX/TX seq numbers: 2933/2934
SPI underruns 0, overruns 0
Number of disconnects: 0
Buffer RX/TX: 0/0-0
=== Duet Control Server ===
Duet Control Server v3.1.1
Code buffer space: 2048
Full transfers per second: 31.02 -
Can you post a directory listing of your sys directory.
I'd also like to see the start of a gcode file that crashes.
If you enter G28 in the DWC console does that home correctly?
If you connect a console via USB (not the DWC console) and enter G28 does that home correctly (be ready to reset/power off just in case!).
@gloomyandy nothing happens it says sending, but no movement. Using pronterface and usb cable
try using something other than pronterface if you can. That tends to do various odd things. Just use a terminal emulation program like YAT or putty. You should be able to issue gcode code commands like M122 and have the responses come back.
@gloomyandy when i enter g28 in dwc is homes perfectly fine
@gloomyandy i can use m122 in putty, but g28 does nothing again
In putty enter:
M111 P3 S1
M111 P16 S1
G28
and post the output. If G28 still does nothing, type G28 in the DWC console and again post the output from the USB console. You may need to scroll back to see the output. -
@gloomyandy Debugging enabled for modules: GCodes(3)
Debugging disabled for modules: Platform(0) Network(1) Webserver(2) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) WiFi(14) Display(15) LinuxInterface(16)
USB: M111 P16 S1
Debugging enabled for modules: GCodes(3) LinuxInterface(16)
USB: G28( G28 didnt do anything btw )
keeps gettin flagged as spam, i messaged you in discord, and sent a TXT of the output during the g28
@gloomyandy I also noticed the output in putty when connected to dwc, has a bunch of connected establishment codes and a bunch of continueing code that gets generated,basically stating the printer is connected blah blah.
When i have dwc off, and just using putty there are no lines being generated from consol. Its like my printer only has its brains. When dwc is connected, ( could i have screwed up setup that bad? ) or is that normal?
What exactly do you mean by having "dwc off"? In all of these tests you need to have your rPi running and connected. If you did not that would explain why G28 was not do anything when you typed it from putty. You can't use the SBC version of RRF without having the rPi/DSF connected.
It is getting pretty late here, so I've got to go.
You should probably set the option in the putty terminal settings:
Implicit CR in every LF
makes the output easier to read.I'd still like to see the directory listing of your /opt/dsf/sd/sys directory.
Please reboot your LPC board. Make sure that DWC is connected and then connect using putty over USB (keep the rPi on and DWC running) then enter:
M111 P3 S1
M111 P16 S1
G28
M122
and post the output. -
