RRF and Heaters – Duet 2 WIFI 3.1.1
After updating my board to 3.1.1 from 2.03, using RRF my Heaters stop working.
My current temperature reading for both is -273.1 c.
First thing that I notice is that the RRF didn’t create a M140 and M143 for the Nozle thermistor. Is that a bug?My config
; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Nov 12 2020 15:24:07 GMT+0000 (Hora padrão da Europa Ocidental); General preferences
M550 P"AA 300x300x600" ; set printer name
M669 K1 ; select CoreXY mode; Network
M551 P"AA" ; set password
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X80.00 Y80.00 Z400.00 E98.50 ; set steps per mm
M566 X950.00 Y950.00 Z30.00 E3000.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z1000.00 E3300.00 ; set maximum speeds (mm/min)
M201 X3100.00 Y3100.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
M906 X1850 Y1850 Z1750 E1750 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X10 Y10 Z0 S1 ; set axis minima
M208 X300 Y300 Z570 S0 ; set axis maxima; Endstops
M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin !xstop
M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F120 T10000 ; set Z probe type to bltouch and the dive height + speeds
G31 P25 X24 Y0 Z2.425 ; set Z probe trigger value, offset and trigger height (quanto mais elevado Z, mais proximo da mesa)
M557 X50:250 Y50:250 S25 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 C570.5 ; configure sensor 0 as thermistor on pin bedtemp
M143 H0 S110 ; set temperature limit for heater 0 to 110C
M308 S1 P"e0temp" Y"thermistor" T100000 B4138 C202.3 ; configure sensor 1 as thermistor on pin e0temp
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M563 P0 S"Extr 1" D0 H1 F0 ; define tool 0
T0 ; select first tool
My old config
; generated by RepRapFirmware Configuration Tool v2.1.3 on Thu Nov 28 2019 16:04:13 GMT+0000 (Hora padrão da Europa Ocidental)...
M307 H0 A105.5 C570.5 D0.2 V23.6 B0 ; disable bang-bang mode for the bed heater and set PWM limit
M305 P0 T100000 B3950 R4700 ; set thermistor + ADC parameters for heater 0
M307 H1 A695.2 C202.3 D10.4 V23.6 B0 ; disable bang-bang mode for the bed heater and set PWM limit
M305 P1 T100000 B4092 R4700 ; set thermistor + ADC parameters for heater 1
M143 H1 S290 ; set temperature limit for heater 1 to 280C -
@MJCT said in RRF and Heaters – Duet 2 WIFI 3.1.1:
M308 S1 P"e0temp" Y"thermistor" T100000 B4138 C202.3 ; configure sensor 1 as thermistor on pin e0tempas i told you in the other thread
your thermistor settings are incorrect B4138 is the default but you also specified a c value.
find the correct values in your thermistor documentation -
@Veti said in RRF and Heaters – Duet 2 WIFI 3.1.1:
find the correct values in your thermistor documentationHi there Veti, thanks again for your attention
Can I specify the values that I had previously in my old config in the RRF, so that It automatically generates de heaters code for me?
Should I erase the data from the 0:/sys/config-override.g?
yes you can use those values
And I believe you have to retune your heaters when moving from RRF2 to RRF3 anyway -
What does retune mean exactly?
Tried M303
Got
M303 H1 S265
Error: M303: heater 1 reported error 'sensor open circuit' at start of auto tuning -
That means you have issues with your thermistor.
What is showing in DWC? -
@jay_s_uk said in RRF and Heaters – Duet 2 WIFI 3.1.1:
What is showing in DWC?Both my thermistors where working perfectly before the update and I didn’t touched the wirings so…..
By DWC you mean this? (Sorry I'm just an end user)
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
Board ID: 08DJM-9178L-L4MSJ-6J9F0-3S46Q-KT3YP
Used output buffers: 3 of 24 (20 max)
Static ram: 27980
Dynamic ram: 93884 of which 60 recycled
Exception stack ram used: 304
Never used ram: 8844
Tasks: NETWORK(ready,332) HEAT(blocked,504) MAIN(running,1848) IDLE(ready,80)
Owned mutexes: WiFi(NETWORK)
Last reset 00:21:01 ago, cause: power up
Last software reset at 2020-11-12 16:16, reason: User, spinning module GCodes, available RAM 8596 bytes (slot 0)
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x04417000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
Error status: 0
MCU temperature: min 46.4, current 48.2, max 48.6
Supply voltage: min 23.9, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
Date/time: 2020-11-13 10:18:09
Cache data hit count 2059511898
Slowest loop: 7.28ms; fastest: 0.14ms
=== Storage ===
Free file entries: 10
SD card longest read time 3.7ms, write time 0.0ms, max retries 0
Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
=== MainDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 42.97ms; fastest: 0.00ms
Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.23
WiFi MAC address ec:fa:bc:01:d4:c6
WiFi Vcc 3.38, reset reason Unknown
WiFi flash size 4194304, free heap 21384
WiFi IP address 192.168.10.62
WiFi signal strength -52dBm, reconnections 0, sleep mode modem
- WiFi -
Can't see anything wrong with what you have in your config. (assuming you made the changes to the M308 we discussed earlier)
If you sendM98 P"config.g"
What comes up?
M98 P"config.g"
M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled -
Manually I did this
M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 C570.5 ; configure sensor 0 as thermistor on pin bedtemp
M308 S1 P"e0temp" Y"thermistor" T100000 B4092 C202.3 ; configure sensor 1 as thermistor on pin e0temp
M140 H1 ;
M143 H1 S290 ;No luck
no you can not. they will lead to the result you are seeing.
delete C570.5 and C202.3
@Veti What do I put in place?
nothing
@Veti like this?
M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
M140 H1 ;
M143 H1 S290 ; -
@MJCT
yes -
@Veti Yes!!!!
Now, two questions
Why didn’t the RRF created a M140 and M143 codes for the H1 (I did it manually)?
Can (should) I run a new M307 for each thermistors? If so, do I need to erase 0:/sys/config-override.g or should I just leave it alone? -
@MJCT run M303 for each heater.
Once complete run M500 and it will over write the values in config-override -
i think there is a bug regarding this in the configurator
yes its required on rrf3 (at least for the bed)
currently its not used because there is not M501 in your config.g
this also means you can not save values with M500
