PT1000 under heaterband
https://nl.rs-online.com/web/p/platinum-resistance-temperature-sensors/4573596?cm_mmc=NL-PLA-DS3A--google--PLA_NL_NL_Automation_%26_Control_Gear_Whoop--(NL:Whoop%21)+Platinum+Resistance+Temperature+Sensors--4573596&matchtype=&aud-826607888547:pla-337006323533&gclid=CjwKCAiA-f78BRBbEiwATKRRBHKjwc9eOcrE-EOTubGatWMWtCC69Qty15oUHY3XsNwbDANqlNHivhoCDqUQAvD_BwE&gclsrc=aw.ds
Will this pt1000 be possible to use with the duet wifi 2 directly mounted under a heater bend of pellet extruder?
that look like a normal pt1000 sensor.
and very similar to the one i am using for my bed.
https://www.aliexpress.com/item/32872179878.html -
I am using similar pt1000 for printbed and chamber temperature sensing.
Ok, I ordered these, will test them asap thanks
