Log temperatures for post analysis
@bearer duet wifi+duex5 on latest fw 3
I thought there is somesort of debugging/logging function that generates log (m929 ?).
Would be nice if it just logged temperatures on sensors like every 0.5 or 1 second reading interval.. any extra parameters would be supercool.Example #1
I am inserting a thermistor in a hemera’s heatsink. Just looking at DWC and logging stuff manually is a bad way of doing it. Log would show the gradual increase (or not) throughout a print.#2
Ambient temperature in relation to buildspace temperature throughout a 24 hour print.List goes on.
That would be very helpful stuff
I don’t have explicit coding skills, but friends do, so is there an API for this? So a separate service would just read and log from DWC?
@MaracMB said in Log temperatures for post analysis:
m929 only logs start/stop of prints, so no good for graphing temps.
you could use daemon.g with M118 to send a message containing a object model refrence to serial or telnet, and collect the data there; or use M408 from serial or telnet to poll data from the duet - or M409 for a more targeted query of the object model
M111 enables debug info, not sure of contents and intervals - might affect operation but you could poke it and see what you find?
you can also query the duet with M408/M409 using HTTP, but in generall it'll be a bit of DIY i think,
tampermonkey to capture the temp graph from DWC might be an option; there have been a few other threads on the same topic, maybe search to see if I missed someting
@bearer thank you. At least i have some options now. I think tampermonkey would be best as it wouldn't load the duet at all. fan tastic
btw if you missed this, it might be of interest?
https://forum.duet3d.com/topic/18688/firmware-package-3-2beta1-released?_=1600243427741although the post wasn't clear if it would work with a duet2 running rrf3.2 or just a duet3 in standalone mode - the mention of dsf that runs on the sbc made it a bit confusing.
oooook... that confused the hell out of me.
i'm no expert but i guess this would then need raspberry pi and not sure if this even runs on Duet2... as you said. confusion is building up.for a simple guy like me, tampermonkey is best bet.
sleep
tell me more about this thing you call sleep?:P
anyways, if you could share your work I'm sure others will appreciate it. as mentioned there has been a couple of similar threads recently. godspeed!
i edited/deleted because i thought you won't get it
i'll call my coding brain friend and will share if anything comes out of this.
Thank you for a very constructive debate.
try the links in this thread?
https://forum.duet3d.com/post/178347 -
@bearer found it. thank you
