My corexy hbot configurations and build pictures
the results of the M303 H1 S240
M307 H1 was used to get this info after the M303 H1 S240:
Heater 1 model: gain 869.9, time constant 308.4, dead time 3.1, max PWM 1.00, calibration voltage 24.2, mode PID, inverted no, frequency default
Computed PID parameters for setpoint change: P20.7, I0.672, D44.3
Computed PID parameters for load change: P20.does it auto save this info? or how and where do i add this
Is it H-bot or corexy? AFAIK, it can't be both...
@mrehorstdmd hbot
so after auto tuning and creating this :
M307 H1 A869.9 C308.4 D3.1 V24.2 B0
where in the config.g do i place it?
what is the B0? for -
@tracar said in My corexy hbot configurations and build pictures:
after the
M950 H1
commandB0 Disables Bang Bang and enables PID mode.
@Veti said in My corexy hbot configurations and build pictures:
M950 H1
im still on firmware version 2.03 -
you should at least update to 2.0.5.1. That should work without config adjustment.
However at some point you have to invest the time to update to rrf3
in rrf2 place it after the other M305 commands.
like this ?
M305 P0 T100000 B3724 R4700 ; set thermistor + ADC parameters for heater 0
M305 P1 T100000 B3724 R4700 ; set thermistor + ADC parameters for heater 1
M307 H1 A869.9 C308.4 D3.1 V24.2 B0 -
yes. dont forget to pid tune your bed as well.
i hav not installed the bed heater and wired for 110v yet
B3724
where did you get that value from?
@Veti
M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0reduced the 4138 by 10%
the bed has the exact same thermister..
that was for the A Parameter of M307 if you have overshoot. not for the B Value of the Thermistor. Overshoot has nothing to do with the thermistor. The B Value of the thermistor is to calculate the temperature based on the resistance of the thermistor. if the beta value is wrong the displayed temperature is wrong.
i.e it could show 240 C but the actual value would be 200 C
@Veti
i have changed it back to the default values.so when i run the M303 H1 S240
the testy begins, finishes and i can display the results with M307 h1.do i have to manually enter them only once in the m307 line, OR is this automatically enterd? or how and what do i need to add to do this automatically?
you have to save it manually in the config.g as it is written in the guide (as you have not enabled the M500 command for you config)
