Duet3D Mainboard+Daughter board+PT100
Ok change the position of your bed thermistor on the board to 0 and you should be done.
thank you guys, i will never get it done on my own, one more thing my heated bed has a ntc 100k, I need to configure that to, can you guys help me?
@Reaperrhs
So is mine -
the sensor on my bed is reading -273, I change the pin on my board to 0 and i left config as it is
Add that
M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0In place of
M308 S0 P"temp0" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin temp0 -
i comment out the one i have and copy
Still reading -273 -
What printer is it ? or bed heater ?
to be exact is a silicone pad that I using on my heated bed
Change to B3950
i think is the thermistor, i plug a didn't one and is reading, so..i really want to thanks for the help, you guys get this thing working, big thumbs up to you guys
