What happens to the temperature inside your nozzle?
@ All. For info - I'll shortly be running those tests again with a home made silicone "sock" around the nozzle. And I'll be detailing a very cheap and quick method to make such a sock.
I'm calling it a "nozzle trainer sock". A sock (as in item of clothing) covers the foot and ankle, but here in the UK, one can buy "trainer" socks, which cover just the foot but not the ankle. This sock covers the nozzle but not the hot block - hence "nozzle trainer sock".
I'll do another blog post and put a link on this forum in the next couple of days or so.
Certainly I never took your test or your post as a slag on metal/steel nozzles, simply realizing that I am not necessarily using the best nozzle for my current printing needs.
When I first got into 3D printing with my Creality CR10S, I frequented its reddit sub. Over time the answer being shared around bothered me because every problem can't be "under extrusion".
Since I converted my now three printers two Duet board and started participating in this forum, I have learned so much, especially volumetric flow rates and their place in printing. Focusing on nozzle pressure made so much sense to me.
With this information that you have provided compliments that info. I still don't know exactly how the correlate, but if a certain amount of volume pressure in the nozzle is needed to maintain the quality of print, then exact nozzle temperature would need to be a highlighted aspect of that.
@zapta These nozzles look great. I will certainly look into these.
@RyanP said in What happens to the temperature inside your nozzle?:
But on top of that, it makes me think greatly about the impact of cooling near the nozzle. Maybe the cooling ducts that are popular are thought to be great, but over doing their job and causing heat loss in unexpected ways.
They may be.. or they may not be. Or perhaps that are, but we are compensating for it somehow. If the fan was really cooling the filament within the nozzle to a significant degree, wouldn't it be reasonable that many people would notice print issues on their 2nd or 3rd layer (or at the lowest layer they turn on their cooling fan?)
I can tell you that often times I have failures when I think I know "the why" of what I'm doing - and more often have successes when I just figure things out with trial and error. That tells me that either I don't really know "the why", or that I only know enough to make me dangerous.
As an example, I have the perfect part cooling (in theory.) It's a berd-air ring that blows down at a ~45 degree from a ring at the nozzle. It's high pressure and low volume, so it shouldn't "over cool" the part. It's arranged in a way that it can't blow directly on the nozzle (and the volume of air is low enough that defection should mostly be muffled inside the infill of a partially printed part.) Yet, if I don't carefully balance filament temperature and cooling air pressure, my PLA prints either curl madly on overhangs or I get insane amounts of stringing. Oh, and because the universe loves to kick me in the face when I think I understand "the why", I get MORE stringing at lower filament temperatures (which is exactly the opposite of popular opinion. )
(This isn't meant to derail the thread - it's only an example of how knowledge isn't always helpful, and sometimes can be harmful.)
Anyway, the kind of stuff that Ian is doing is actually helpful to me in many ways. I can't say that I've ever been able to DIRECTLY take something on his blog and use it, but many times I've read things and said to myself.. "aaah! That might explain..."
Oh, and up until recently, I've almost exclusively used E3D hardened steel nozzles. They let me switch between filament types without having to change nozzles as often. Recently, however, I ended up switching from 0.8mm steel nozzle to brass and found an improvement in flow with that size nozzle. (Ironically, I had my part cooling fan turned off for those prints.) With 0.4mm nozzles, I've never noticed any effective difference in printing with brass vs hardened steel. I also never had a need to vary temperatures for different nozzle types (though I do let my hot end temperature "settle" for a couple minutes before starting a print - so perhaps that gives the hardened steel time to get up to the proper temp.)
Every single word you typed sounds like my experiences lately. Problems....solutions....why?....don't know. Same problem, different solution, why?....don't know.
This forum has proven itself invaluable when it comes to finding the solutions. The Whys are sometimes there, but other times it can be more like "Try this, it may fix it".
We all have to take out individual machines, and filter through all the experience of each other to find what actually works on our own machines.
@zapta Those nozzles look interesting. I'd be a bit concerned about the sensor falling out. How is it retained?
Also, as I mentioned in my blog, if you do have localised cooling of the nozzle (as opposed to the hot block) then potentially you could end up heating the filament inside the hot block to 30 Deg C or more higher than the normal print temperature. If that happened with PET-G, it would carbonise and you'll never clean it out, so you could end up with a wrecked hot end. Therefore, use with caution and be especially careful not to have part cooling air blowing over the nozzle. -
First, I think most people blow way too much air on their parts. When using PLA, you almost don't need to blow air at all, except in specific areas, to preserve small details. I think slicers should take that into account. For example, why blowing air during infill? It just reduces the layer adhesion!
Second, what about blowing hot air? It needs to be below the glass transition temperature. This is what Stratasys does: the chamber is kept at 100°C (ABS), and the fans blow air at that temperature. And they blow a lot of air (2 big fans on each side).
@garyd9 said in What happens to the temperature inside your nozzle?:
If you look at any decent nozzle seller you will see that with steel nozzles they say "you need to increase your print temp by 10 degrees"
@fma Regarding the temperature of the cooling air, I think I covered all that in my blog. I was especially careful to note the ambient temperature and the fact that the bed was unheated, so any deflected air might be cooler that if the bed was heated.
I would be hesitant to say that "most people blow way too much air on their parts". I haven't seen the results of any surveys asking people what volume flow rate they use, have you? Is that statement based on any factual data or are just guessing?
Also this statement quote - "When using PLA, you almost don't need to blow air at all, except in specific areas, to preserve small details"
...... is only be true for certain nozzle sizes and slowish speeds. When using larger nozzles and/or printing at high speed, one can lay down a lot of plastic in a very short space of time. If cooling isn't used, then the previous layer will still be at or above the Tg temperature when the next layer is added resulting in the printed part sagging.
@deckingman said in What happens to the temperature inside your nozzle?:
Facts: I meet a lot of people doing 3D printing in my hackerspace and around, and I see what they are doing.
Yes, true. That's why I do think that an heated chamber keeping the part at the correct temperature¹ would be a huge improvement, even for PLA. This way, you don't have to bother that much with air flow.
¹ finding that correct temperature would need some experiment, though, and probably change for each filament brand/color/...
@fma said in What happens to the temperature inside your nozzle?:
I started my 3d printing "experience" with "difficult to print materials" PP and HDPE (and HDPE800 which is some even higher density polyethylene than normal HDPE and warps even worse), so I'm experimenting with heated chambers for almost a decade. WRT PLA 25-30C is kinda best printing temperature, and temp of the air you blow is best around 25-30C. Blowing hotter air (e.g. 40C) produces very bad prints. Try it yourself. There was a huge issue UP printers had with PLA where the designer made the air that cools the heatbreak work as part cooling too and no matter how much air they pushed the results were terrible. That air was 40-45C. Bringing colder, room temp air, to cool the part solved all the issues. You can find measurements and discussions in lenght on the pp3dp forum.
ABS works great in 70C chamber with 70C air being circulated in the chamber (no need to blow directly under the nozzle, enough to circulate air. I made it usually in the way that first layer of air going from the heaters creates laminar flow over the top layer of the print (never actually visualised the flow but..) and it works ok, problem is hotend's heatbreak, I experimented with a lot of stuff (peltie's, external air trough tubes etc...) and so far water is the only thing that works ok, but those are all hotends I made myself and are not "very good" (single piece aluminium turned on lathe, no multimaterial heatbreak, no interchangeable nozzle ..)... today there are some interesting solutions available that one should try but one needs time
PC is similar only chamber temp 130C works better than 70C.
PP is on the other hand super nasty to print, it's Tg is 0C but I had best print quality with 40-50C chamber and very slow air movement (208C printing temp and slow 8-12mm/sec print speed with pauses on small layers)
cooler nozzle than the block is expected, it is important that low conductivity nozzles are not too long so that temp differential to the tip is not too big. You compensate for the tip temperature by increasing the temp of the heater block. If the nozzle is too long you have to get your block "too hot" and that can damage the filament, but as long as the required heat increase is in the safe zone for the filament you don't have a problem, you just need to temp-tower find the best temp for certain print settings (fan speed, nozzle size, print speed, layer height, extrusion width combo).
Thanks for the feedback!
@arhi said in What happens to the temperature inside your nozzle?:
Yeah, My Up! Mini is not so great for PLA for this reason. Almost considering adding a pump to get outside air for PLA when the conversion is done.
It seems that the enclosure temperature should remains 30°C below the glass transition temperature (confirmed by @arhi, which uses 70°C for ABS). So, for PLA, 30°C is the max.
@bearer said in What happens to the temperature inside your nozzle?:
There are upgrades I made for up! / up! plus / up! plus 2 that solve this by separating part cooling fan from heatsink fan and that move heatsink air away from the part being printed, helps a lot makes it totally usable for PLA... I use my mini for ABS and PC only so I never tackled to redesign it's extruder assembly as for ABS/PC/HIPS it works as is ( I only upgraded the bed heater from 18W to 80W so it can actually get to required temp for PC and added printbite surface as original one is utter .. )
I disagree. I'm not a chemist and I don't trust "specification" as Tg for some plastic is a number in a book, and name of the plastic filament is made of is a name on a box. What the actual plastic in the box is and what the actual Tg of that plastic is without "measurement" (no clue how to measure) we don't know. As I seen ABS that prints normally at 220C and I seen ABS (e.g. the one from pp3dp) that prints at minimum 260-270C .. those both print on same extruder, same hotend, same sensors... so def are not both "same ABS"..
Furthermore, polypropylene Tg is 0C!! HDPE is below zero, iirc -40C and you need to heat the chamber over 40C to print them so that's like 80 over Tg not below
I'll stick with
- I have no idea what filament require what temperature (bed, nozzle, chamber)
- I have no idea what filament is cooled with what amount of how hot air
- in order to get best results, I test each batch - temperature tower, temperature tower, temperature tower... till I'm satisfied with results
But yes, 100C for PC, 70C for ABS/HIPS and 30C for PLA are values I use for env. if I can
In the examples I saw, they hold it in mechanically. Some people mentioned adding a thermal compound.
As said, I use little silicone band around it (sticking to itself). It maintains the thermistor, and make a good insulation. And I use their fiber-glass+silicone as final insulation around the ceramic cartridge. This make a very small hotend, allowing to have fan ducts close to the nozzle. Combined to a berd air pump, this allows very accurate air flow.
Further results
https://somei3deas.wordpress.com/2020/05/24/quick-and-cheap-diy-nozzle-trainer-socks/
This thread seems to have been hijacked so make of them what you will.........
........... or do your own tests
........... or continue to chat about printers/filaments/heated chambers/life in general,
........... whatever makes you happy. -
Here is a picture of a ceramic heater and a thermistor in the nozzle that is well covered by a silicon sock. It's compact, symmetric (non need to align) and well isolated. Should handle better deflected air (?). I wonder why this style is not that popular.
(from https://www.deltaprintr.com/)
I have a Stratasys BST 1200es in my garage - here is how they separate part cooling and "heatbreak" cooling.
On the print head is an air plenum, where an "umbilical cord/tube" is attached, with the airflow powered by a 120VAC blower fan. This air is drawn from outside of the printer - so assume 25°C or so.
Both the support (left) and model (right) material are extruded with the same DC motor. Some air is directed downward, parallel to the filament, while some is directly just about perpendicular to the filament (right above where it enters the heater).
You can see below that, directly above the heater, there is an angled metal sheet that lines up pretty close to the outlets of the horizontal filament cooling air, controlling the direction of the air and preventing it from passing down towards the print nozzle.
The Dimension series has a heated chamber, set to ~72°C, with the heated air directed over the build plate at roughly the height of the current layer being printed. On the print head air plenum there is a slit on the support side, directing ~25°C air towards the currently printed area. I am unsure if this print cooling air is used only for support or if its for both, as the print head moves depending on what material is selected - if model is selected, it looks like the support nozzle and tip shroud blocks the airflow somewhat. As a note, this blower fan does not turn off except in certain maintenance modes, so the cooling air is not turned off depending on what material is being printed.
The tip shrouds cover a significant amount of nozzle tip, so the impacts of the cooling air (or even blowing chamber air) is limited.
When compared to "reprap" style hotend setups, "heatbreak" cooling flow is quite controlled, the print cooling flow is extremely focused and controlled, and the impact of fluid flow over the nozzle(s) is reduced.
