DuetLapse available for Alpha testing
https://vimeo.com/415279225
Is an effort with pla. Used detect - pause, with M226 in the gcode at each layer change. The extra frames have to be deleted before running ffmpeg again -
some, not so recent, rpi installation ...
root@octopi:~/DuetLapse# ./DuetLapse.py -h Traceback (most recent call last): File "./DuetLapse.py", line 21, in <module> import DuetWebAPI as DWA File "/root/DuetLapse/DuetWebAPI.py", line 27 URL=(f'{self._base_url}'+'/rr_status?type=1') ^ SyntaxError: invalid syntax root@octopi:~/DuetLapse# python3 python3 python3.5 python3.5m python3m root@octopi:~/DuetLapse# python3 DuetLapse.py -h Traceback (most recent call last): File "DuetLapse.py", line 21, in <module> import DuetWebAPI as DWA File "/root/DuetLapse/DuetWebAPI.py", line 27 URL=(f'{self._base_url}'+'/rr_status?type=1') ^ SyntaxError: invalid syntax root@octopi:~/DuetLapse#
after rpi-update
root@octopi:~/DuetLapse# python3 --version Python 3.5.3 root@octopi:~/DuetLapse# python3 ./DuetLapse.py -h Traceback (most recent call last): File "./DuetLapse.py", line 21, in <module> import DuetWebAPI as DWA File "/root/DuetLapse/DuetWebAPI.py", line 27 URL=(f'{self._base_url}'+'/rr_status?type=1') ^ SyntaxError: invalid syntax root@octopi:~/DuetLapse# python3 ./DuetLapse.py Traceback (most recent call last): File "./DuetLapse.py", line 21, in <module> import DuetWebAPI as DWA File "/root/DuetLapse/DuetWebAPI.py", line 27 URL=(f'{self._base_url}'+'/rr_status?type=1') ^ SyntaxError: invalid syntax root@octopi:~/DuetLapse#
hm and just in case wget messed something up .. git clone of both repos
root@octopi:~/DuetLapse/DuetLapse# PYTHONPATH=/root/DuetLapse/DuetWebAPI python3 DuetLapse.py -h Traceback (most recent call last): File "DuetLapse.py", line 21, in <module> import DuetWebAPI as DWA File "/root/DuetLapse/DuetWebAPI/DuetWebAPI.py", line 27 URL=(f'{self._base_url}'+'/rr_status?type=1') ^ SyntaxError: invalid syntax root@octopi:~/DuetLapse/DuetLapse#
I don't get it, I don't see that this line changed since forever?!
looks like F-Strings are in from 3.6 only raspbian on pi3b+ latest comes with 3.5.3
@arhi said in DuetLapse available for Alpha testing:
@arhi Very interesting, I don't get that, and that line is not a syntax error. Hmmm... Let me think of a way to pin this down.
@Danal said in DuetLapse available for Alpha testing:
F-strings are 3.6 python from what I read online, and stretch has max python 3.5.3 ... I'm now going to move to buster and see if it uses newer python
Excellent detective work. I had no idea f was that recent.
@Danal I don't use python at all so I don't have anything but what's normally there with the distro... so, troubles with buster too it comes with newer python but again
root@octopi:~/DuetLapse/DuetLapse# apt-get install python3-numpy python-numpy Reading package lists... Done Building dependency tree Reading state information... Done python-numpy is already the newest version (1:1.16.2-1). python3-numpy is already the newest version (1:1.16.2-1). root@octopi:~/DuetLapse/DuetLapse# python3 DuetLapse.py -h Python Library Module 'numpy' is required. Obtain via 'sudo python3 -m pip install numpy' root@octopi:~/DuetLapse/DuetLapse# python3 DuetLapse.py Python Library Module 'numpy' is required. Obtain via 'sudo python3 -m pip install numpy' root@octopi:~/DuetLapse/DuetLapse# python3 DuetLapse.py -h Python Library Module 'numpy' is required. Obtain via 'sudo python3 -m pip install numpy' root@octopi:~/DuetLapse/DuetLapse# python3 -m pip install numpy Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple Requirement already satisfied: numpy in /usr/local/lib/python3.7/dist-packages (1.18.4) root@octopi:~/DuetLapse/DuetLapse# pip3 install numpy Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple Requirement already satisfied: numpy in /usr/local/lib/python3.7/dist-packages (1.18.4) root@octopi:~/DuetLapse/DuetLapse# python3 DuetLapse.py -h Python Library Module 'numpy' is required. Obtain via 'sudo python3 -m pip install numpy' root@octopi:~/DuetLapse/DuetLapse# python3 --version Python 3.7.3 root@octopi:~/DuetLapse/DuetLapse#
root@octopi:~# python3 Python 3.7.3 (default, Dec 20 2019, 18:57:59) [GCC 8.3.0] on linux Type "help", "copyright", "credits" or "license" for more information. >>> import subprocess >>> import sys >>> import argparse >>> import time >>> import numpy as np Traceback (most recent call last): File "/usr/local/lib/python3.7/dist-packages/numpy/core/__init__.py", line 24, in <module> from . import multiarray File "/usr/local/lib/python3.7/dist-packages/numpy/core/multiarray.py", line 14, in <module> from . import overrides File "/usr/local/lib/python3.7/dist-packages/numpy/core/overrides.py", line 7, in <module> from numpy.core._multiarray_umath import ( ImportError: libf77blas.so.3: cannot open shared object file: No such file or directory During handling of the above exception, another exception occurred: Traceback (most recent call last): File "<stdin>", line 1, in <module> File "/usr/local/lib/python3.7/dist-packages/numpy/__init__.py", line 142, in <module> from . import core File "/usr/local/lib/python3.7/dist-packages/numpy/core/__init__.py", line 50, in <module> raise ImportError(msg) ImportError: IMPORTANT: PLEASE READ THIS FOR ADVICE ON HOW TO SOLVE THIS ISSUE! Importing the numpy C-extensions failed. This error can happen for many reasons, often due to issues with your setup or how NumPy was installed. We have compiled some common reasons and troubleshooting tips at: https://numpy.org/devdocs/user/troubleshooting-importerror.html Please note and check the following: * The Python version is: Python3.7 from "/usr/bin/python3" * The NumPy version is: "1.18.4" and make sure that they are the versions you expect. Please carefully study the documentation linked above for further help. Original error was: libf77blas.so.3: cannot open shared object file: No such file or directory >>>
I love how consistent APT system is
apt-get install libatlas-base-dev
solved the numpy error
one hint, I don't know python but might be cool to add argument to DuetLapse to point to DuetWebAPI library?
I added directly to code
diff --git a/DuetLapse.py b/DuetLapse.py index eee4a51..5119d61 100755 --- a/DuetLapse.py +++ b/DuetLapse.py @@ -17,6 +17,9 @@ import subprocess import sys import argparse import time + +sys.path.insert(1, "../DuetWebAPI/"); + try: import DuetWebAPI as DWA except ImportError:
but would be cool to read that from the argument line
so we can normally git pull changes and not need to copy stuff over each other
especially as python is ignoring symlinks
@Danal you tested this with 3.01RC12? and DWC 2.1.7?
root@octopi:~/DuetLapse/DuetLapse# cd ../DuetWebAPI/ root@octopi:~/DuetLapse/DuetWebAPI# git pull Already up to date. root@octopi:~/DuetLapse/DuetWebAPI# cd - /root/DuetLapse/DuetLapse root@octopi:~/DuetLapse/DuetLapse# python3 DuetLapse.py -duet ender5.local.lan -camera usb -detect layer -pause no Attempting to connect to printer at ender5.local.lan http://ender5.local.lan does not appear to be a RRF2 or RRF3 printer Device at ender5.local.lan either did not respond or is not a Duet V2 or V3 printer. root@octopi:~/DuetLapse/DuetLapse# fping ender5.local.lan ender5.local.lan is alive root@octopi:~/DuetLapse/DuetLapse#
root@octopi:~/DuetLapse/DuetLapse# telnet ender5.local.lan Trying 192.168.89.246... Connected to ender5.local.lan. Escape character is '^]'. M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.01-RC12 running on Duet Ethernet 1.02 or later ... telnet> c Connection closed. root@octopi:~/DuetLapse/DuetLapse#
this last part was on me - works ok now
@Danal I don't know python so this should probbly be done better by somehow defining parameter to onePhoto() not mandatory, or if there's already a global with this info but this works awesome for me so if you like you integrate
root@octopi:~/DuetLapse/DuetLapse# git diff diff --git a/DuetLapse.py b/DuetLapse.py old mode 100755 new mode 100644 index eee4a51..1539257 --- a/DuetLapse.py +++ b/DuetLapse.py @@ -17,6 +17,9 @@ import subprocess import sys import argparse import time + +sys.path.insert(1, "../DuetWebAPI/"); + try: import DuetWebAPI as DWA except ImportError: @@ -204,11 +207,15 @@ def unPause(): printer.gCode('M24') alreadyPaused = False -def onePhoto(): +def onePhoto(zl): global frame frame += 1 s="{0:08d}".format(int(np.around(frame))) - fn = '/tmp/DuetLapse/IMG'+s+'.jpeg' + if (zl > -1): + zlayer="{0:8d}".format(int(zl)) + fn = '--title "Layer '+zlayer+'" /tmp/DuetLapse/IMG'+s+'.jpeg' + else: + fn = ' /tmp/DuetLapse/IMG'+s+'.jpeg' if ('usb' in camera): if (camparms == ''): @@ -226,6 +233,7 @@ def onePhoto(): else: cmd = 'wget '+camparms+' -O '+fn+' "'+weburl+'" ' + print(cmd) subprocess.call(cmd, shell=True) global timePriorPhoto timePriorPhoto = time.time() @@ -240,20 +248,20 @@ def oneInterval(): # Z changed, take a picture. checkForcePause() print('Capturing frame {0:5d} at X{1:4.2f} Y{2:4.2f} Z{3:4.2f} Layer {4:d}'.format(int(np.around(frame)),printer.getCoords()['X'],printer.getCoords()['Y'],printer.getCoords()['Z'],zn)) - onePhoto() + onePhoto(zn) zo = zn global timePriorPhoto elap = (time.time() - timePriorPhoto) if ((seconds) and (seconds < elap)): checkForcePause() print('Capturing frame {0:5d} after {1:4.2f} seconds elapsed.'.format(int(np.around(frame)),elap)) - onePhoto() + onePhoto( -1 ) if ('pause' in detect): if ('paused' in printer.getStatus()): global alreadyPaused alreadyPaused = True print('Pause Detected, capturing frame {0:5d}'.format(int(np.around(frame)),elap)) - onePhoto() + onePhoto( -1) unPause() def postProcess(): root@octopi:~/DuetLapse/DuetLapse#
(print(cmd) was just me debuging, that's not needed)
Python honors symlinks, that is exactly how I'm keeping one central copy of DuetWebAPI and not copying it around to each DuetLapse, TAMV, etc, etc. as I develop this stuff. If you want it not in the current directory, and/or don't want to use symlinks, then properly put it in Python's path please.
By the way, git clone will NOT update things, 'wget' has all kinds of edge cases, I haven't found a really bullet proof way to distribute scripts from github (besides set up a package server. Which I am reluctant to do, and even that requires entries in /etc directories on user endpoints).
Anyway, symlinks work fine, I'm curious why yours don't.
ln -s ../DuetWebAPI/DuetWebAPI.py DuetWebAPI.py
right?Screenshot to get colors:
kill me if I know why but it didn't work .. I'll try again later but this work as is now so ...
Need to try that again, when I did with
it was finding api ok but failed something else, but maybe now that I fixed the other thing that will work, will tryBy the way, git clone will NOT update things
of course, git pull does ( git checkout or stash first if files are modified
like they are now)
git clone
git pull
git checkout/stashworks awesome, the only issue I need to handle is this path for libs so it knows how to find api, will retest this but even as is it's not a biggy
hahaha retested the symthing now, it works, the %^$#*&^#
works too, I'll use this way .. the problem was obviously the numpy or whatever is that thing called...anyhow, these are irrelevant parts of that diff
.. what about that change in the onePhoto() ? makes sense?
Don't you just love things like that!
anyhow, these are irrelevant parts of that diff .. what about that change in the onePhoto() ? makes sense?
Makes perfect sense, I just need time to look at it... probably next day or two.
I'm not 40 any more, doing things between 3 and 5am obviously need to be doublechecked
@Adrian52 said in DuetLapse available for Alpha testing:
Great program, but I still have not got it quite right. I am currently using. /DuetLapse - duet 192.168.1.16 -camera pi -detect pause, with M25 and M400 added to each layer in gcode (easy to do in kisslicer). The problem is that two frames are taken, one when the head is moved away by pause.g, the second a bit later, when the print has resumed. I also get an error message on the console 'm24: cannot print because no file is selected'. It looks as though the m24 is being sent twice.
I have edited my pause.g so that there is no z shift.Just pushed changes to the detect pause logic that should eliminate this. It has been tested to ensure no syntax errors, but has not been run through a print.
@Danal here is my first go
https://vimeo.com/415969620
Worked fine with M226 in the gcode file. Excellent. Will try detecting layer changes later. Great work. -
I was attempting to run this on the same PI as my OctoPrint setup. I kept getting errors saying numpy wasn't installed. After attempting the suggested command to get numpy installed, it claimed that pip wasn't installed for python3. After a lot of googling I got pip and numpy installed, but I was still getting the same error saying numpy was required.
I finally added some additional output to DuetLapse.py file and found that I was getting the following error:
It looks like the answer to that error was to run
sudo apt-get install libatlas-base-dev
I just thought I would post this here in case anyone else runs into this issue, or if anyone has a better way to solve it. I am novice with Linux and Python, so this may not be the best way to handle things.
I am using the following versions of OctoPrint/OctoPi:
OctoPrint version: 1.4.0
OctoPi version: 0.17.0
