Solved Question about M564
My duet is driving a 1000x1000 workbee cnc and I'm having some issues with homing. I had an M564 command in my config file which allowed me to drive the machine without having to home it to allow me to home the machine earlier but since taken the command out. Before taking M564 S0 H0 out of config, I was able to home everything individually and home all successfully. No, my machine will home Z, but not X, Y, or All. Additionally, it will not home all even if I have everything commented out except for the Z moves (which was proven to work with homing Z alone).
The machine's max area is X770 Y800 Y94. The errors I'm getting is a "G28 G0/G1 target position outside machine limits". I'm wondering if I were to put an M564 S0 H0 command at the beginning of homeall.g and M564 S1 H1 command at the end of homeall.g, will it turn off soft limits during homing sequence then turn soft limits back on when its finished? Does anyone have any other possible solutions to my issue?
probably better to post your home file(s) and get the appropriate G0 moves with H1 set. (i suppose we'd need the M574 and M208 config(s) as well to verify)
Yes, please post your files. config.g and home-.g
It should never be necessary to turn off limits, or turn on "move without homing", to home. Getting axis limit definitions right, and the content of the various homex.g files, homing will work on (almost) any setup, without changing those.
@Danal I'm at work so give me a few hours to provide them. Do you want me to give the files or is copy/paste enough?
Either way. If you do copy paste, please put three backticks on a line by themselves at the start/end of the paste.
This
some text
more text
```Does this
some text more text
@Danal I'm gonna test this since I never done that before
test line 1 test line 2
That is cool! Okay, I'll be back in a few hours with the routines. I'll tag you. Thanks.
@Danal I'm giving you my config.g, customconfig.g, homex.g, homey.g, homez.g, and homeall.g.
config.g
; Configure Drives M569 P0 S0 ; Drive 0 goes forwards M569 P1 S1 ; Drive 1 goes forwards M569 P2 S0 ; Drive 2 goes forwards M569 P3 S1 ; Drive 3 goes forwards M584 X0 Y1:3 Z2 ; Apply drive mapping to axes ; Configure Axes M92 X400 Y400 Z400 ; Set steps per mm M350 X16 Y16 Z16 I1 ; Configure microstepping M566 X500 Y500 Z500 ; Set maximum instantaneous speed changes (mm/min) M203 X2500 Y2500 Z2500 ; Set maximum speeds (mm/min) M201 X150 Y150 Z150 ; Set accelerations (mm/s^2) M906 X2400 Y2400 Z2400 I100 ; Set motor currents (mA) ; Configure Axis Limits M208 X0 Y0 Z0 S1 ; Set axis minima M208 X800 Y770 Z94 S0 ; Set axis maxima ; Configure Endstops M574 X2 Y2 Z2 S0 ; Set active low endstops ; Other Settings M140 H-1 ; Disable heated bed M564 S1 H1 ; Disable jog commands when not homed M911 S21.0 R23 P"G91 G1 Z3 F1000" ; Configure power loss resume M501 ; Load Stored Parameters M98 Pcustomconfig.g ; Execute custom config settings
customconfig.g
; ADD ANY CUSTOM SETTINGS BELOW ; Configure Drives M569 P0 S0 ; Drive 0 (X) goes forwards M569 P1 S1 ; Drive 1 (Y1) goes forwards M569 P2 S0 ; Drive 2 (Z) goes forwards M569 P3 S1 ; Drive 3 (Y2) goes forwards ; Configure Axis M906 X1000 Y1000 Z1000 I100 ; Set motor currents (mA) ; Configure Endstops M574 X2 Y2 Z1 S1 ; Set active high endstops
homex.g
; homex.g ; called to home the X axis G91 ; relative positioning G21 ; Set units to mm G1 H1 Z94 F900 ; move quickly to Z axis endstop and stop there (first pass) G1 Z-3 F2400 ; go back a few mm G1 H1 Z94 F300 ; move slowly to z axis endstop once more (second pass) G1 H1 X1500 F2400 ; move quickly to X and Y axis endstops and stop there (first pass) G92 X800 Z94 ; Set Home Position please - to your machine size. G1 X-3 F2400 ; go back a few mm G1 H1 X1500 F300 ; move slowly to X and Y axis endstops once more (second pass) G92 X800 Z94 ; Set Home Position please - to your machine size. G90 ; absolute positioning
homey.g
; homey.g ; called to home the Y axis G91 ; relative positioning G21 ; Set units to mm G1 H1 Z94 F900 ; move quickly to Z axis endstop and stop there (first pass) G1 Z-3 F2400 ; go back a few mm G1 H1 Z94 F300 ; move slowly to z axis endstop once more (second pass) G1 H1 Y1500 F2400 ; move quickly to X and Y axis endstops and stop there (first pass) G92 Y770 Z94 ; Set Home Position - change to your machine size. G1 Y-3 F2400 ; go back a few mm G1 H1 Y1500 F300 ; move slowly to X and Y axis endstops once more (second pass) G92 Y770 Z94 ; Set Home Position - change to your machine size. G90 ; absolute positioning
homez.g
; homez.g ; called to home the Z axis G91 ; relative positioning G21 ; Set units to mm G1 H1 Z94 F1500 ; move quickly to Z axis endstop and stop there (first pass) G92 Z94 ; Set Home Position - change to your machine size. G1 Z-3 F2400 ; go back a few mm G1 H1 Z94 F300 ; move slowly to X axis endstop once more (second pass) G92 Z94 ; Set Home Position - change to your machine size. G90 ; absolute positioning
homeall.g
; homeall.g ; called to home all axes G91 ; relative positioning G21 ; Set units to mm G1 H1 Z94 F900 ; move quickly to Z axis endstop and stop there (first pass) G1 Z-3 F2400 ; go back a few mm G1 H1 Z94 F300 ; move slowly to z axis endstop once more (second pass) G1 H1 X1500 Y1500 F2400 ; move quickly to X and Y axis endstops and stop there (first pass) G92 X800 Y770 Z94 ; Set Home Position - change to your machine size. G1 X-3 Y-3 F2400 ; go back a few mm G1 H1 X1500 Y1500 F300 ; move slowly to X and Y axis endstops once more (second pass) G92 X800 Y770 Z94 ; Set Home Position please change to your machine size. G90 ; absolute positioning
as the second line needs H1 or H2 depending on what you want to achieve. In general you want to home z first and avoid it in the first place i think
Several things to clean up before we solve the real problem:
@Perseveranze said in Question about M564:
These should be separated (even if this statement works).
AND, every move in home.g should have H1 or H2 in it, even if we don't expect it to hit the switch. (the -3 move)
G1 H1 X1500 F2400
G1 H1 X-3 F2400
G1 H1 X1500G1 H1 Y1500 F2400
G1 H1 Y-3 F2400
G1 H1 Y1500@Perseveranze said in Question about M564:
All the G92 should go away completely. If that results in the coordinate being off after homing, we will fix that a different way.
This also should not be present, or more specifically, if there are any H0 commands anywhere else, they should go away.
Try that, and see if it homes at all. Again, if it homes but coordinates are wrong, we will fix that a different way.
Oh, and it looks like your limit switches on X and Y are at max, correct?
@Danal I'll start working at editing my files right away, and yes, I home at max
@Danal Everything works as intended now!
Thank you so much guys!
