Hi at this please help
Configuration file for Duet WiFi (firmware version 3)
; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Feb 21 2020 16:39:28 GMT+0100 (Mitteleuropäische Normalzeit); General preferences
M550 P"Mister" ; set printer nameM667 S1 ; select CoreXY mode
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M586 P2 S0 ; disable TelnetM555 P1 ; Set firmware compatibility to look like Marlinxxxxxxxxxxxxx
M569 P0 S0 ;E physical drive 0 goes forwards
M569 P1 S0 ;X physical drive 1 goes forwards
M569 P2 S1 ;Y physical drive 2 goes forwards
M569 P3 S1 ;Z physical drive 3 goes forwards
M350 X16 Y16 Z16 E16 I0 ; configure microstepping without interpolation
M92 X80 Y80 Z793.6 E98.03 ; set steps per mm
M566 X2000 Y2000 Z20 E1000 ; set maximum instantaneous speed changes (mm/min)
M203 X9000.00 Y9000.00 Z600.00 E6000.00 ; set maximum speeds (mm/min)
M201 X800.00 Y800.00 Z200.00 E800.00 ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S120 ; Set idle timeout; Axis Limits
M208 X300 Y260 Z310.40 S0 ; set axis maxima; Endstops
M574 Z2 S0 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop; Z-Probe
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 P9 C"zprobe.in+zprobe.mod" H5 F400 T9000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X0 Y0 Z4.45 ; set Z probe trigger value, offset and trigger height
M557 X1:300 Y1:260 S60 ; define mesh grid; BED
M308 S0 P"bedtemp" Y"PT1000" X500 ; configure sensor 0 as thermistor on pin bedtemp
M307 H0 A269.0 C392.3 D2.9 B0
M305 P0 T100000 X500 R4700
M140 H0 ; map heated bed to heater 0; HOTEND
M308 S1 P"e0temp" Y"PT1000"T100000 X501 ; configure sensor 1 as thermistor on pin e0temp
M307 H1 B0 S1 ; disable bang-bang mode for heater and set PWM limit
M307 H1 A438.8 C250.7 D5.7 B0
M305 P1 T100000 X501 R4700; Fans
M106 P0 S0 H1 T100 ; set fan 0 value. Thermostatic control is turned on
M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off; Tools
M563 P1 F0:1 ; define tool 1
G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C; Miscellaneous
M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
T0 ; select first tool -
@PaulHew said in Hi at this please help:
extruder calibration
Hello, thank you for helping me, extruder has been calibrated
extruder has been calibrated but the error remains despite what remains.
Thanks Eder -
So you have changed your M92 E value?
I would suggest that you go through this part of a superb guide.
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s165Make sure your E steps are correct, then print the calibration cube to tune you flow rate.
I would start with PLA filament before moving on to other filament types such as PET-G.Get the basics right first, I have been known to miss these crucial steps!
Have you upgraded recently?
This post is deleted! -
@eder said in Hi at this please help:
yes i have ok i try
hello, has gotten better but the problem remains despite: - ((
Hi, I got similar problem with exactly same model to print
But in my case whole model prints very well except first layers corners and corners only were over extruded.
Since in your print it is in bottom and up layers, that might suggest that you could have a look on slicer settings for top/bottom check if you have some hidden settings in slicer and unhide them. Hope you find a clue.Regarding mine problem I wasn't even looking for that solution just because I have generally something very wrong with filament flow in my setup...
I remember seeing somewhere setting (or something) that has something to do with extrusion in slows down for cornering, but can't remember where. I'll post if I find.
thanks monster for information i look times
