3.3 volt LED doesn’t light up, WiFi module doesn’t turn on
I recently bought a duet 2 WiFi board and after setting it up and attaching the wiring from my Ender 3 the 3.3 v LED won’t light up and this includes while trying to have the usb cable in to try and get the WiFi module to turn on so that I can access the web control.
if removing the sd card doesn't make any difference odds are something is broken.
ref https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
Your awesome. It worked. Thank You
Additional question for you not that the board is showing those lights. What should I do for the WiFi module because the light for it isn’t lit up in the normal blue led as it should be
Without an SD card that has a config file with
M552 S1
wifi won't start. So put in a working SD card with a valid config?If the bord hasn't been previously connected to wifi you'll need to add the wifi first. ref https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
Cool that all worked. I took the sd card that I put the configuration files on out and put an sd card that has g.code files on it but it says that it failed to retrieve files of this directory. Do I have to create a directory for the sd card or is there something in the configuration files that I have to change?
The card that came with the board should have had all the files and directories needed? Did that card never work?
See the sd card structure link after reading this https://duet3d.dozuki.com/Wiki/SD_Card
I’m not entirely sure I pretty sure it has all the files considering I followed the dozuki of how to set up the board. I will just have to reupload the files I had on the sd card I used before getting the duet 2 WiFi board, which I had used for the print files.
