FTP transfer problem
I am unable to transfer files using FTP connection from PC to the Duet while listing or deleting files is working fine.
using last version of filezilla.
I have created an entry in Site Manager for the Duet, and set it to "Max concurrent connections: 1".; Network M550 PATLAS Technic 4030 ; Set machine name M552 S1 ; Enable network Module M586 P0 S1 ; Enable HTTP M586 P1 S1 ; Disable FTP M586 P2 S0 ; Disable Telnet
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet Ethernet 1.02 or later Board ID: 08DGM-917NK-F23T0-6J9FL-3S46J-KDAWD Used output buffers: 1 of 20 (14 max) === RTOS === Static ram: 25524 Dynamic ram: 98304 of which 0 recycled Exception stack ram used: 344 Never used ram: 6900 Tasks: NETWORK(ready,544) HEAT(blocked,832) MAIN(running,3860) IDLE(ready,200) Owned mutexes: === Platform === Last reset 00:18:08 ago, cause: software Last software reset at 2019-03-21 10:41, reason: User, spinning module GCodes, available RAM 6916 bytes (slot 1) Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d Error status: 0 Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest block write time: 0.0ms, max retries 0 MCU temperature: min 34.8, current 36.2, max 36.3 Supply voltage: min 24.1, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: standstill, SG min/max 441/736 Driver 1: standstill, SG min/max 416/738 Driver 2: standstill, SG min/max 379/722 Driver 3: standstill, SG min/max not available Driver 4: standstill, SG min/max not available Date/time: 2019-03-21 10:59:21 Cache data hit count 2730962867 Slowest loop: 21.12ms; fastest: 0.07ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0 === Move === Hiccups: 5, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 237, MaxWait: 481439ms, Underruns: 0, 0 Scheduled moves: 5, completed moves: 5 Bed compensation in use: none Bed probe heights: 0.000 0.000 0.000 0.000 0.000 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Stack records: 1 allocated, 0 in use Movement lock held by null http is idle in state(s) 0 telnet is idle in state(s) 0 file is idle in state(s) 0 serial is idle in state(s) 0 aux is idle in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 21.42ms; fastest: 0.02ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(1) Telnet(0) Telnet(0) HTTP sessions: 1 of 8 Interface state 5, link 100Mbps full duplex
updated to the latest 2.03beta2 but still not working.
Update, Using CoreFTP the transfers works as expected, so this is a Filezilla missconfiguration I think. But i havent changed any of the options
I am having similar problems with Cyberduck on Mac. Set it to use a single connection ('use browser connection') but can't download/upload, just list directories and files.
I am 80% sure it used to work before I updated the firmware.
@zapta try another ftp client, for me filezilla is not working while CoreFTP works just fine
FileZilla works for me with the following settings:
- Tab General: Encryption - Only use plain FTP (insecure)
- Tab General: Logon Type - Anonymous
- Tab Advanced: Server Type - Default
- Tab Tranfer Setting: Tranfer Mode - Passive
And if your on a mac.
- Tab Charset - Force UTF-8
