Magic smoke and stopped working
also see if you can get a close up of this area, without the shade
@bearer Thats a pain, are there any places where they can fix this sort of thing? I have a friend with a reflow station but I'm not sure how fancy it is
Would depend on where you're located I guess. But a hot air rework station might get the job done if you take the time to "soak" the board and get the whole area up to 100-120C for 2-3 minutes before trying to remove the part. Or stick it in the oven to preheat it; or cut off the legs leaving you with only the tab to desolder with an iron.
As you don't need to salvage the part the main concern is to avoid lifting traces and pads.
Oh, and yeah, the USB port might need replacing as well, current clearly took the path through the ground lead there.
Ah that's a bummer, any idea what could've caused it in the first place? Don't want to get it fixed and then plug it in for the same thing to happen
see the posts boldnuts and dc42
what did the other end of the USB cable go to?
There was a micro usb extender so it had a panel mount type thing, then that plugged into a regular micro usb cable which went into my PC in a usb3.0 port. the cable is pretty ruined
You might want to take a look at the computer as well then unfortunately. There is also no guarantee everything else works after replacing U2, and you have to remove the chip, or at least isolate the output leg to test for further damage.
The PC and printer were plugged into the same multi plug so not sure about ground loops with that. (there were also monitors and speakers but I'm not sure if that makes a difference). The power wires all seem secure as well so I'm stumped
i was thinking about the USB port on the computer, it might also be damaged, even if it works now.
odds are the wiring problen is as dc42 suggest, between the duet and the power supply; are all the screw terminals tight? you should consider some sort of crimp terminal or ferrule on the power supply side in any case.
the usb port on the computer seems to work ok for now. All the terminals are tight, absolutely no give in them. When this happened the printer shouldn't have been drawing much current, no heaters turned on or anything like that but I'm not sure if that makes a difference
I've taken the board off the printer (nothing connected anymore) and taken the U2 regulator off, there is a short over the outputs where it was connected.
Suppose you can disconnect the etherned module, but beyond that a current limited supply and seeing what gets hot its not easy to identify which other parts have failed.
I removed the ethernet module, and the short seems to be gone! So i guess something in the ethernet module has popped, no idea what though
good news is you can buy just the ethernet module.
but if you're certain the Duet wiring was not to blame I'd be concerned you have a ground fault somewhere in your mains wiring. is your electrical installation fitted with RCD/GFCI's?
Electric water heater or stove tops are the prime suspects for ground faults after outdoor outlets and outdoor lighting.
I'll do that Apparently the plug it was plugged into has been a bit dodgy for years, so now I know where the problem is! Do you know which microusb port I should get? Looks like there's a lot of similar but slightly different kinds
This post is deleted! -
@logriso said in Magic smoke and stopped working:
Hi at all, I'm a newbie and I follow this chat since the begin.
@hiro_ono, I'm very sorry about your problem... And I hope cause is only the eth module... @bearer, I don't know what does mean RCD GFC -
@bearer coukd you please explain to me? I will prepare the wiring for my 3d printer and I want to be sure to connect everything in the right way, before apply power supply. Thanks a lot
