Homing Inconsistent Duet 3
Looks pretty much exactly like mine on the Jubilee:
; Home X Axis G91 ; Set relative mode G1 X-999 F6000 H1 ; Big negative move to search for endstop G1 X4 F600 ; Back off the endstop G1 X-10 F600 H1 ; Find endstop again slowly G90 ; Set absolute mode G1 X0 F6000
I do see an interesting difference in our config.g: Your X endstop:
M574 X1 S1 P"!io2.in" ; configure active-low endstop for low end on X via pin io2.inMine:
M574 X1 S1 P"io1.in" ; Set homing switch configuration X1 = low-end, S1 = active-high (NC)I'm wondering why the invert, the "!"... Are your switches "normally closed"? If they are "normally open", I wonder if the input pin is picking up noise when the motors are moving? I'd switch the physical wiring to "normally closed"... but, as a quick test, maybe add pullup to your definition and see what happens?
M574 X1 S1 P"!^io2.in"P.S. I notice you are using io0.in for Y endstop. Documentation says don't use 0, it is reserved for PanelDue. However, I have used it; I missed that document at first. It seemed to work just fine.
Normally Open - My RB's were wired like that and I stick with it. no other reason than that.
Not going to say its 100% not the wiring, but this is a setup that has been fully working for a few months without changes, including the io0.in, but you're right, I could move that.
This works 100% of the time I just home X, using the script. If it was mechanical/electrical, I would expect it to behave similarly with the single call.
I'll give pullup a try, but I'm not confident it will make a difference.
@Luke-sLaboratory said in Homing Inconsistent Duet 3:
M201 X2000.00 Y2000.00 Z18 E2500:2500:2500 C400
have you tried reducing accelerations?
@Luke-sLaboratory my problem is exactly the same.
My first guess was that the optical endstop has a problem. I changed my Hypercube to sensoreless homing. Which works greatMy homeall.g looks exactly like yours
But anyhow the issue is still the same.
Yeah, and it is easy to sit here and say "Change this, change that"... but... I'd still recommend going normally closed. For one thing, it inherently detects any wiring flaws.
"Worked for months". Could be a version change of the firmware, but much more likely to be something that changed, very subtly, in the hardware. Connection becoming slightly flakey, etc.
RE: The io0... I used it for months before I found the document. So I wouldn't change it. Also, it is Y, correct? And your real problem is with X.
In summary: I certainly can't explain how it worked or what changed. Nonetheless, I'd swap to NC.
Curious - what would acceleration do for homing?
Its not actuating the switch from pure inertia, it just thinks the button is always pressed for some reason. -
I hear ya, I hear ya
The problem is that N.O can't randomly close the connection, Both ends on my switches are heat shrunk, and the other ends are properly sitting in their crimped spots.
If it was NC, yeah, if i had a poor connection, it would make sense if something broke, but here wires would have to wear+arc, and that isn't the case, at least as long as I can see, nor does it show up in firmware.
I found that If i power restart the machine, the first home works correctly, but any subsequent homes do not until reset again.
We'll see what RC4 brings us.
it has more to do connections breaking rather than being made; if the NO switch gets disconnected your homing will crash. If your NC switch becomes disconnected it can be detected and crashes avoided (although the common homing sequences does not seem to take advantage of that)
Bearer is correct on one of the prime underlying reasons for the industry "best practice" for NC.
Luke, in your case, I don't suspect wiring causing an issue in terms of a wire itself causing a false trigger... I've worked with you on other discords and you "do things right" on crimping and wiring and such... Instead, I suspect "noise" or a "floating wire" or "capacitance" or something similar. Can't prove it... really don't know why it used to work and works once after a power cycle... but I do know that NC puts the wiring in a "known state", namely hard pull to ground, until that switch clicks.
The more I think about that "works once after a power cycle" the more I become convinced this is a "floating wire" issue. After power cycle, that wire is ???? Neutral ??? I don't know what word to use.
After the first home (that works), the wire becomes "charged" or "discharged" or something.
Maybe.
@Luke-sLaboratory i have no idea. the only thing i know is that after setting acceleration to a higher value homing[xy] ceased to work. after lowering acceleration homing was working. --> https://forum.duet3d.com/topic/14614/unable-to-home-xyz-using-my-homing-scripts?_=1584452867098
@spllg said in Homing Inconsistent Duet 3:
AHHH! New data point! (Maybe I missed it earlier). Let me think about that for a while.
@bearer
I agree in practice - My comment in this thread was addressing how much harder it is to get a false positive (switch shows ON when it shouldn't be) connection with a N.O switch.
I recognize the preferred convention is to fail safe by having a NC switch that should error check that its a closed circuit.
@spllg No clue there - It has been working with these values for several months, only recently has there been an issue.
@Danal Lmk when you figure it out - no issues sofar in RC4, but that's 3 datapoints
i would think a hard pull down to ground is more stable than a weak pull up when it comes to coupled or induced noise?
@T3P3Tony So finally it happened again, again this was during homing procedures.
DuetControlServer does NOT hang or fail in a way that the linux OS understands
This is the message in the console, it is erroneous - whatever mechanism is used to determine the RRF 'availability' is failing and not the homing process - the mechanism causing the 'Transport endpoint is not connected' error is the problem here.
22/03/2020, 12:31:28 G28 Y Error: Operation failed (Reason: Transport endpoint is not connected) 22/03/2020, 12:31:28 Error: G0/G1: insufficient axes homed
This is the report from sysctl - clearly shows duetcontrolserver is still running - but it has stopped communicating with the Pi
pi@duet3:~ $ sudo systemctl -l status duetcontrolserver ā duetcontrolserver.service - Duet Control Server Loaded: loaded (/lib/systemd/system/duetcontrolserver.service; enabled; vendor preset: enabled) Active: active (running) since Sun 2020-03-22 00:29:41 GMT; 12h ago Main PID: 340 (DuetControlServ) Tasks: 15 (limit: 4915) Memory: 50.9M CGroup: /system.slice/duetcontrolserver.service āā340 /opt/dsf/bin/DuetControlServer Mar 22 12:24:54 duet3 DuetControlServer[340]: [info] Executing nested macro file config-override.g on channel Trigger Mar 22 12:24:54 duet3 DuetControlServer[340]: [info] Trigger: Finished macro file config-override.g Mar 22 12:24:54 duet3 DuetControlServer[340]: [info] Trigger: Finished system macro file config.g Mar 22 12:31:02 duet3 DuetControlServer[340]: [info] Executing nested macro file homex.g on channel HTTP Mar 22 12:31:16 duet3 DuetControlServer[340]: [info] HTTP: Finished macro file homex.g Mar 22 12:31:16 duet3 DuetControlServer[340]: [info] Executing nested macro file homey.g on channel HTTP Mar 22 12:31:28 duet3 DuetControlServer[340]: [info] Received file abort request on channel HTTP for all files Mar 22 12:31:28 duet3 DuetControlServer[340]: [info] Aborted macro file Mar 22 12:31:28 duet3 DuetControlServer[340]: [warn] HTTP: Out-of-order reply: 'G0/G1: insufficient axes homed' Mar 22 12:31:28 duet3 DuetControlServer[340]: [error] G0/G1: insufficient axes homed pi@duet3:~ $
The journal contains the same messages.
pi@duet3:~ $ sudo journalctl -fu duetcontrolserver -- Logs begin at Thu 2019-02-14 10:11:59 GMT. -- Mar 22 12:24:54 duet3 DuetControlServer[340]: [info] Executing nested macro file config-override.g on channel Trigger Mar 22 12:24:54 duet3 DuetControlServer[340]: [info] Trigger: Finished macro file config-override.g Mar 22 12:24:54 duet3 DuetControlServer[340]: [info] Trigger: Finished system macro file config.g Mar 22 12:31:02 duet3 DuetControlServer[340]: [info] Executing nested macro file homex.g on channel HTTP Mar 22 12:31:16 duet3 DuetControlServer[340]: [info] HTTP: Finished macro file homex.g Mar 22 12:31:16 duet3 DuetControlServer[340]: [info] Executing nested macro file homey.g on channel HTTP Mar 22 12:31:28 duet3 DuetControlServer[340]: [info] Received file abort request on channel HTTP for all files Mar 22 12:31:28 duet3 DuetControlServer[340]: [info] Aborted macro file Mar 22 12:31:28 duet3 DuetControlServer[340]: [warn] HTTP: Out-of-order reply: 'G0/G1: insufficient axes homed' Mar 22 12:31:28 duet3 DuetControlServer[340]: [error] G0/G1: insufficient axes homed
The message 'executing nested macro' is misleading - these macros are not nested unless the Pi or something in the background is doing this - my homex, homey and homez are all independent, when this failure occured I was homing axes individually. The error insufficiant axes homed is also erroneous. I was actually homing at the time of the error and not executing any command that required the axes to be homed.
Anything in the queue remains in the queue and the interface appears to be hung - it is NOT hung - it is waiting for a macro to complete that never will. When this transport error occurs the system needs to clear any outstanding queued commands and attempt to re-establish communication.
The time is also incorrect - the systemctl reports that the system has been running for 12 hours - it has not, it was started at approx 10am
-- Logs begin at Thu 2019-02-14 10:11:59 GMT. -- Mar 22 12:45:01 duet3 CRON[17414]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1) Mar 22 12:45:01 duet3 CRON[17410]: pam_unix(cron:session): session closed for user root Mar 22 12:47:53 duet3 sudo[17864]: pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/bin/journalctl -fu duetcontrolserver Mar 22 12:47:53 duet3 sudo[17864]: pam_unix(sudo:session): session opened for user root by pi(uid=0) Mar 22 12:48:00 duet3 sudo[17864]: pam_unix(sudo:session): session closed for user root Mar 22 12:49:47 duet3 sudo[18117]: pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/bin/journalctl -fu Mar 22 12:49:47 duet3 sudo[18117]: pam_unix(sudo:session): session opened for user root by pi(uid=0) Mar 22 12:49:47 duet3 sudo[18117]: pam_unix(sudo:session): session closed for user root Mar 22 12:49:51 duet3 sudo[18142]: pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/bin/journalctl -f Mar 22 12:49:51 duet3 sudo[18142]: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Is the time a clue ? and why is it so messed up .... I'm not a linux fan and this isn't helping that opinion
RE: Time
@Garfield said in Homing Inconsistent Duet 3:
-- Logs begin at Thu 2019-02-14 10:11:59 GMT. --Check your system time zone. They come out of the box set to GMT.
ssh to the Pi and enter
sudo raspi-config
Use the menus to check the time zone, etc. In fact, if you just go to those menus (localization, time zone) and don't change anything, and back out, you will find something like the below in the console session after you back completely out of raspi-config. This also lets you verify how it is currently setup.Current default time zone: 'America/Chicago' Local time is now: Sun Mar 22 14:36:29 CDT 2020. Universal Time is now: Sun Mar 22 19:36:29 UTC 2020.
Not sure what you see that makes you think that? The log entry timestamps like "Mar 22 12:49:51" are a time of day, not a duration since boot. Again, timezone may affect this.
This entry in the systemctl status states that it has been running since 00:29:41
Regardless of the timezone that is incorrect
RE: Nested
In this case, "Nested" means the DSF was already executing a G28, and that called a macro. Please note this is chrishamm's code, and it's really the way his mind works that determines this word in a log message; there is not a technically correct or incorrect answer here.
Anyway, if it helps, the complete output from homing a single axis is below.
Agreed, this seems like a bug.
Mar 22 14:39:27 duet3 DuetWebServer[468]: info: Microsoft.AspNetCore.Hosting.Diagnostics[1] Mar 22 14:39:27 duet3 DuetWebServer[468]: Request starting HTTP/1.1 POST http://192.168.7.101/machine/code text/plain;charset=UTF-8 5 Mar 22 14:39:27 duet3 DuetWebServer[468]: info: Microsoft.AspNetCore.Cors.Infrastructure.CorsService[4] Mar 22 14:39:27 duet3 DuetWebServer[468]: CORS policy execution successful. Mar 22 14:39:27 duet3 DuetWebServer[468]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[0] Mar 22 14:39:27 duet3 DuetWebServer[468]: Executing endpoint 'DuetWebServer.Controllers.MachineController.DoCode (DuetWebServer)' Mar 22 14:39:27 duet3 DuetWebServer[468]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[3] Mar 22 14:39:27 duet3 DuetWebServer[468]: Route matched with {action = "DoCode", controller = "Machine"}. Executing controller action with signature System.Threading.Tasks.Task`1[Microsoft.As pNetCore.Mvc.IActionResult] DoCode() on controller DuetWebServer.Controllers.MachineController (DuetWebServer). Mar 22 14:39:27 duet3 DuetWebServer[468]: info: DuetWebServer.Controllers.MachineController[0] Mar 22 14:39:27 duet3 DuetWebServer[468]: [DoCode] Executing code 'G28 X' Mar 22 14:39:28 duet3 DuetControlServer[359]: [info] Executing nested macro file homex.g on channel HTTP Mar 22 14:39:33 duet3 DuetControlServer[359]: [info] HTTP: Finished macro file homex.g Mar 22 14:39:33 duet3 DuetWebServer[468]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ContentResultExecutor[1] Mar 22 14:39:33 duet3 DuetWebServer[468]: Executing ContentResult with HTTP Response ContentType of text/plain; charset=utf-8 Mar 22 14:39:33 duet3 DuetWebServer[468]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2] Mar 22 14:39:33 duet3 DuetWebServer[468]: Executed action DuetWebServer.Controllers.MachineController.DoCode (DuetWebServer) in 5771.5376ms Mar 22 14:39:33 duet3 DuetWebServer[468]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[1] Mar 22 14:39:33 duet3 DuetWebServer[468]: Executed endpoint 'DuetWebServer.Controllers.MachineController.DoCode (DuetWebServer)' Mar 22 14:39:33 duet3 DuetWebServer[468]: info: Microsoft.AspNetCore.Hosting.Diagnostics[2] Mar 22 14:39:33 duet3 DuetWebServer[468]: Request finished in 5772.2764ms 200 text/plain; charset=utf-8
Excellent, thanks, let me look at that...
