such as a very thin Feeler gauge like the 0.05mm one from this set from Halfords http://www.halfords.com/workshop-tools/tools/hand-tools/halfords-feeler-gauge-metric-and-imperial-16-blades
Doug
Got some 3mm thick PEI Sheet on it's way to me as well
And don't forgot you can do an "auto first layer" height calibration by sending G30 (RRF) G30 Z0 (smoothie) after levelling/calibration to recheck z=0 and reset it (from bed centre ideally but shouldn't matter if your calibration/levelling are accurate). Assuming you set the z-probe offset correctly you should now get exactly the first layer height you sliced.
Its worth checking the offset with something thinner than paper if you have something that would work.
Is there a reference for using G30 after a bed level is done? Can it be done after mesh levelling? I must have missed that.
Ive done the
G92 Z0
G1 Z5
G30 S-1and it reports a value of 0.0x across the bed.
When printing it drops below the z0 plane and hits my printbite.@DC42: OK, when I rip it apart, I'll try spraying the rear of the printbite to see what effect it has.
Kraegar - reference, not really but it was discussed here: https://www.duet3d.com/forum/thread.php?id=940#p9288
Yes you can do it after mesh levelling it does not clear the mesh (or calibration) it merely probes and resets z to the probed point.Phytone - You dont need the G92 Z0. Just run mesh/calib. then go to centre
G1 Z5
G30You don't need the S-1 this parameter is only information and reports the height difference.
Try that and then see. You height map I am not sure why thats low, can you attach/post your config.g? And Bed.g? -
Did the above, same issue.
; bed.g
; generated by RepRapFirmware Configuration Tool on Sat Feb 04 2017 22:32:57 GMT+0000 (GMT Standard Time); Clear any bed transform
M561; Probe the bed at 5 points
G30 P0 X50 Y50 H2 Z-99999
G30 P1 X50 Y215 H2 Z-99999
G30 P2 X215 Y50 H2 Z-99999
G30 P3 X215 Y215 H2 Z-99999 S -
; Configuration file for Duet WiFi (firmware version 1.17)
; generated by RepRapFirmware Configuration Tool on Sat Feb 04 2017 22:32:57 GMT+0000 (GMT Standard Time); General preferences
M111 S0 ; Debugging off
G21 ; Work in millimetres
G90 ; Send absolute coordinates…
M555 P2 ; Set firmware compatibility to look like Marlin
M208 X230 Y230 Z200 S0 ; Set axis maxima; Endstops
M574 X1 Y1 Z0 S0 ; Define active low and unused microswitches
M558 P1 I1 F500 X0 Y0 Z0 ;analogue piezo sensor output falls on contact, probing speed, not used to home axes
G31 X0 Y0 Z0.03 P700 ;sensor is nozzle and trigger value; Drives
M569 P0 S0 ; Drive 0 goes backwards
M569 P1 S0 ; Drive 1 goes backwards
M92 X80.5 Y80.5 Z405.9 E455.9 ; Set steps per mm
M566 X900 Y900 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
M203 X8000 Y8000 Z180 E2200 ; Set maximum speeds (mm/min)
M201 X800 Y800 Z250 E800 ; Set accelerations (mm/s^2)
M906 X1000 Y1000 Z800 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout; Heaters
M143 S260 ; Set maximum heater temperature to 260C
M305 P0 R4700 T100000 B3950; Set thermistor + ADC parameters for heater 0
M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 X0 Y0 ; Set tool 0 axis offsets
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Network
M550 PPhytone ; Set machine name
M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP; Fans
M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Custom settings are not configured
RepRapFirmware height map file v1, mean error -0.20, deviation 0.04
xmin,xmax,ymin,ymax,radius,spacing,xnum,ynum
60.00,240.00,35.00,220.00,-1.00,40.00,5,5
-0.119, -0.143, -0.094, -0.183, -0.207
-0.205, -0.220, -0.178, -0.092, -0.198
-0.215, -0.205, -0.237, -0.244, -0.173
-0.242, -0.230, -0.210, -0.225, -0.225
-0.230, -0.190, -0.188, -0.156, -0.274 -
and this is the start of a g-code file
;FLAVOR:RepRap
;TIME:2049
;Filament used: 3.66315m
;Layer height: 0.3
;Generated with Cura_SteamEngine 2.4.0
M190 S70
M104 S190
M109 S190
G21 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
G1 Z1.0 F9000 ;move the platform down 1mm
G92 E0 ;zero the extruded length
G1 F200 E3 ;extrude 3mm of feed stock
G92 E0 ;zero the extruded length again
G1 F9000
M117 Printing…
;LAYER_COUNT:83
;LAYER:0
M107
G1 F1800 E-4
G0 F3600 X102.801 Y104.451 Z0.3
;TYPE:SUPPORT
G1 F1800 E0
G1 X137.199 Y104.451 E1.63032
G1 X137.199 Y135.549 E3.10423
G1 X102.801 Y135.549 E4.73455
G1 X102.801 Y104.451 E6.20846
G1 F1800 E2.20846
G0 F3600 X113.873 Y114.036
G0 X113.955 Y114.11
G1 F1800 E6.20846 -
adding G31 Z-0.2 or G31 Z0.2
or extremes like G31 Z-4 or G31 Z 4into the config.g file has NO impact whatsoever.
I'm stumped.
I've only skimmed this a bit tied up, but do you need the H2's in your bed. G?
Edit Yes I suppose you do, I haven't used RRF on a cartesian machine. Hmmm…
Not exactly on topic but have you tried the probe on digital instead of analogue, with low debounce value? You can probe at a higher speed with no false triggers.
I posted my M558 and G31 on a previous page.
Wow, a world of difference using this probe after a couple of minutes setting up:
…This is what I got with DC42's sensor AFTER spraying my aluminium heat bed with black matt paint and probing my Printbite (the sticky tape makes it a bit patchy as in the photo - is this causing the problem?):Yes, the variable reflection from the sticky tape is the problem. With PEI you have to spray paint the back of the PEI matt black, cure it in an oven, then stick it painted side down to the bed plate. I imagine PrintBite is similar.
I can confirm I had issues with print bite and IR sensor when the PB was mounted directly on aluminium plate
I removed the H2 and the auto bed compensation graph was higher, but still under z0. Did a probe, which still showed as also under the bed, went to print and the print head wants to start at somewhere around z-5.
Had enough for today. Will try digital tomorow.
I've been thinking about effector mounting of piezo sensors as opposed to the under bed sensors that I'm using at the moment, here's what I've come up with.
For a long time now I've been mounting my hot end so that the nozzle is as close in height to the arm mounting as possible. I've been doing this for a couple of reasons:
I hate losing build height, I regularly print things that scrape the top of my Kossel Minis 230mm build height, with an underslung hot end I'd probably lose 50mm or more.
I think that a smaller distance between the arms and the nozzle will minimize effector tilt.
With that in mind, here is the first prototype of my integrated piezo effector.
I've soldered brass M3 nuts to the back of the piezo disks which avoids having to drill holes in them. Unfortunately I can't test this on my printer at the moment, my printer is set up with metal [censored] on the arms and cups on the carriages and effector, I need to swap them around but I'm waiting on more steel [censored].
Idris
Its amazing what a day away does…
Nozzle diving below print bed - problem solved.....
Given it was probing nicely, turned my attention to the G-CODE file.
G21 ;metric values
G28 X0 Y0 F6000 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstopsRemoving the G28 Z0 from the code seems to fix it, and it prints at the right height. Now I need to figure out why......
What are you using as your z_min endstop? Is it the piezo probe or do you have a mechanical endstop also?
It's the probe…...
probably makes no difference but why home xy and then z?
Why not just do G28?
You don't need the X0 Y0 coordinates.I doubt thats it but worth a try, also I'd do your Z home at bed centre so maybe
G28 XY F6000
G1 Xx Yy F6000
G28 Z -
New Piezo Z-probe boards are in as well as Piezo Endstop boards if anyone wants to give those a try.
Idris
These piezo's are tough units (using 27mm). In fiddling around, the + wire became detached from the centre (pulled the white stuff off)- thought I'd reattach/solder and hope. Well works fine!
After some more meddling, I am now getting really good results.
This is the best bed mapping that I've ever had on the printer since running duet wifi.
Excellent results that's very satisfying.
Yeah they are quite tough the piezo's. On my test rig I've slammed it into the test bed so hard and so many times, it broke the bracket holding the module, but the piezo was still working like a champ. I've had a few de-soldered wires but soldered them back on with little or no drama. One of the issues moving this forward into a consumer unit is the fragility of the soldered connections on the piezo. My thinking is integrate the control board into the sensor module, thereby reducing the mobility in these wires to zero. It also reduces the (theoretical at this point) risk of interference on the lead to the piezo causing issues. There is another idea involving making the piezo part of the circuit and placing that in between the two parts of the assembly.
