Hot end not working after upgrade to RR3
@dingo007
2000 means there is no thermistor on that connector also delete the Calso your thermistors values are incorrect.
@blt3dp
Noone else would understand why H0 is used for the tool.
To comply with conventions I think it's better not to do that. -
working RR2 config.g
M140 H-1 ; disable heated bed
M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0Cnon-working RR3 config.g
M140 H-1 ; disable heated bed (overrides default heater mapping)
M308 S0 P"e0temp" Y"thermistor" T100000 B4138 R4700 ; configure sensor 0 as thermistor on pin e0temp
M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 0
M143 H1 S280 ; set temperature limit for heater 0 to 280C
M307 H1 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit; Fans
M106 P1 S1 H0 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C -
M308 S0 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin e0temp
M950 H0 C"e0heat" T0 ; create nozzle heater output on e0heat and map it to sensor 0
M143 H0 S280 ; set temperature limit for heater 0 to 280C
M307 H0 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit; Tools
M563 P0 D0 F0 ; define tool 0add it this way
@Veti said in Hot end not working after upgrade to RR3:
sorry
M563 P0 D0 H0 F0 ; define tool 0seems there is a problem with the configurator.
1/10/2020, 11:38:54 PM Printing paused at X0.0 Y0.0 Z0.0
1/10/2020, 11:38:52 PM Resume state saved
Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
1/10/2020, 11:38:47 PM Error: Temperature reading fault on heater 0: unknown temperature sensor channelconfig.g - edited as you said.
M307 H0 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit; Fans
you are on rrf 3.0 and not a beta or a rc?
@Veti whatever rr config gave me when i selected 3.0
whats the output of M115?
@Veti yeah thats the problem, is it not included in config.zip ?
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.04 ELECTRONICS: Duet Ethernet 1.02 or later FIRMWARE_DATE: 2019-11-01b1
@Veti great so i downloaded the proper file and uploaded it to the gui
was prompter to install the latest firmware, i said yes and got thisM997 S0
Error: M997: In-application programming binary "iap4e.bin" not found -
Is that file showing in your sys directory where your config.g is at? If not, you can get it from the Duet2Firmware-2.04.zip listed under assets at this link.
@blt3dp already fixed that thanks
@Veti okay, welp, shot myself in the foot that time i guess.... uploaded the new firmware after fixing iap4e.bin and it works fine now... with the config you gave me...
@dingo007
@Veti
I would like to come back to this issue, just to clarify.
It's also possible to configure the heater to H1 as we have suggested.
I have tested that today, it works.
As well I have checked the RRFCT configuration.
For that case, the tool configuration wasn’t generated correctly.It also seems if multiple subsequent modifications are done by adding/deleting heater or tools the config.g is getting weirder.
It helped to clean up the browser cash.
