Add laser for duet2 wifi
I know you want to buy a circuit... nonetheless, you might want to try this, it can be built for a few cents, and no board:
Note the original diagram shows 13V in. 24V in (from the heater 6 connector) will require NO changes.
It also shows 3.3V out. For five volt out, change the 150K and 39K in the lower right to 100K and 100K.
This is "old school" analog conversion. It will not make the signal any cleaner, but it won't make it any worse, either, in that nothing in that diagram has a limited switching speed.
@Danal said in Add laser for duet2 wifi:
It also shows 3.3V out. For five volt out, change the 150K and 39K in the lower right to 100K and 100K.thanks Danal for your Replay
I think this circuit is easy to build
here you can see the change I make for heater 6-7 -
@yaman said in Add laser for duet2 wifi:
so after Received the part and test
it won't workI'm sorry for putting you off-course with this, I see what you mean about the DC power port being for testing; I'd assumed that was the principle power port, my apologies.
Your values and @Danal 's circuit look much more suitable. And easy to source all the parts for.
For reference in this thread: I just drew up the circuit I plan to drive my similar 15/8w diode laser module from a 3v3 controller (esp32 based) .
I will use an optocoupler, I have some at home already; the basic circuit looks like:
The OutputLimiter resistor is probably being over-cautions, the 4n35 can take 100mA/30v, but the laser module might provide enough residual power on the PWM lines to make it a good idea.
(Edit; I just looked at my circuit, I refer to 'nagative' values, probably a faux-pas, not a typo.] -
@EasyTarget circuit also looks quite good. More "standard" way in the digital world...
@yaman Yes, your modifications to the values are correct. Solder it up, wrap it in tape, and give it a try.
@Danal
here are the complete drawing between Laser ; header and the circuit
do I need to add anything else
@EasyTarget
never mind it's only 10$ -
do I need to add anything elseLooks good to me; I was going to suggest a switch but I see you have that covered.
Looks correct, and the values given will work with a Duet (expansion) at 12V or 24V.
As with any project, verify as much as possible with a voltmeter or o-scope, every step of the way.
@Danal
@EasyTarget
OK so after some work with solder
the circuit not work exactly but after I make little change the Laser finally work
youtube for Laser Test -
AhHA! a 10V pwm input. Same as mine; when I was looking at this last year I'd noted that 10V pwm/analogue seems to be a bit of a standard in the laser world. It's common in many CO2 lasers.
Something like this would work?
https://www.amazon.com/Voltage-0-100-Linear-Conversion-Transmitter/dp/B00U7GJDVO
connected to a fan or heater, take the pwm at 24v and transform it to 0-5V DC
@hector
thanks for you replay
but this circuit will not work in my case because I don't have Fan 2
fan 2 I use it for tool 2
I have heater 6 -7 with 5v PWMhttps://forum.duet3d.com/assets/uploads/files/1570300649740-laser_cable_2.jpg
Sounds like that laser wants 10V in.
Some want 5V (TTL), some want 10V. The two versions of the circuit above will work for the respective cases.
@Danal
@EasyTarget
@T3P3Tony
Thanks for your replay
that what I find maybe the real test will be in G code file and let the machine work for hours
but first I have to do some work at FirmwareRight now I'm at Version 2.0.0-RC2
so any Suggestions for good version work fine with 3dprinter and Laser ? -
I haven't personally tried laser, so can't comment on releases.
I can say I've had very good results using the "latest", including release candidates.
The latest release, always the latest.
https://github.com/dc42/RepRapFirmware/releases/latestDuet makes upgrading super easy, there is no real excuse for not upgrading asap and when new releases come out. Currently it is 2.03.
This is especially true if doing CNC machine control, Duet3D are pushing heavily in this direction at present and related features are appearing in each new release.
If you want to throw caution to the wind, try the latest 2.0x Release candidate, but I would avoid the 3.0 series betas at this time for general users. Though the 3.x series will eventually bring even more CNC related feature goodness.
Laser Engraving picture
@yaman COOL!, it's great when it gets working.
Now you have all the tuning fun you could wish for; carving and engraving is much more of a 'craft' than 3d printing, the sheer range of materials and techniques ensures that every job is a one-off. With my printers I strive for reproducibility, but for laser art I want everything to be slightly 'individual', it's part of the charm. -
