Solved I'm confused about an entry in Dozuki re connecting FSR boards
This is the entry I don't know how to interpret:
" If using JohnSL's trinket board: Connect its Vcc, Output and Ground pins to 3.3V, IN and GND on the Z-probe connector respectively and select mode 5. "
The 3 pins In the corner (under the rectifier ) of the John FSL board are labelled :
Signal , -/+ , +/-
Is Vcc = +/-
Output = Signal
Ground = - / +Thanks for any help
Vcc is normally + and Gnd is normally - but this board features a rectifier on the power input you can connect them any way around, thus the +/- & -/+ notation which can be a bit confusing. But yes, you can connect it as you have laid out.
bearer ,
thank you for the prompt confirmation. I went ahead after receiving your reply and it all works
In case anybody refers to this thread:
On JohnSL board Signal pin is connected to Z_Probe_In pin on Duet
On John SL board +/- pin is connected to +3.3V on Duet
On JohnSL board -/+ pin is connected to GND on Duetand in the config .g file for my delta printer is the following
M558 P5 X0 Y0 Z0 H5 I1
P5 and I1 being the important varaiables
Thanks again
