Movement above 50 mm/s loud
I'll keep that in mind. I have only encountered the 6 wire connectors that work as I described. Thanks!
The other pinout I have come across is 1-4, 3-6. All 4 motors on my Ormerod use this pinout.
I'm right, when I say, the motor is turning right, I connected all right?
@hevilp said in Movement above 50 mm/s loud:
If you are able to move the motor in a controlled way in both directions, then you have connected it correctly.
Okay,
its fine than. I think its nothing with the duet. Speeds above 50 mm/s does stutter, rattle, shaking on the X-axe - carriage and I'm not able to figure it out. It was with rods and now with linear rails, too.
On the video you cannot real hear how loud it is, anyway:
https://www.youtube.com/watch?v=id_A0d7HXlwJust not usable above 50 mm/s, I'm happy with any help here, the printer is jsut garbage with the sounds.
