Low print quality Anycubic i3 Mega with Duet Wifi
Thank a lot for helping, I was able to make print quality little better (but still not good enough) by playing with Cura settings(mostly wall thickness). After I installed duet wifi I took Anycubic i3 Cura profile and changed flavor to reprap, for some reason same settings don't work for duet. Still working on it.
I have a question: with anycubic I didn't had to do wall thickness setting and other too and had great prints, is it just Duet wifi(reprap firmware) thing? Can duet wifi print with same print quality or better as marlin ?
@newyork347 said in Low print quality Anycubic i3 Mega with Duet Wifi:
Yes, most definitely.
Thank You, I think I was able to fix it, I changed extrusion factor on main page to 120% and temperature to 225 for pla, not sure what causing it, will test it tomorrow
Did you tune your heaters and did you perform a extrusion calibration test?
