Duet Wifi heater issue - board reset
Im at a dead end.
Its my first duet wifi setup, however Im facing issues in order to make heatbed and nozzle heat works. In the fact when I try to test it the board reset.All setup is ok. I can home the printer, manage it by wifi, but I cant startup the heatbed and the nozzle.
Nozzle heater is installed at E0.
Need help! Thank you!
Following my config file:
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X15 Y15 Z20 S1 ; set axis minima
M208 X300 Y300 Z350 S0 ; set axis maxima; Endstops
M574 X2 S1 P"!xstop" ; configure active-high endstop for high end on X via pin !xstop
M574 Y2 S1 P"!ystop" ; configure active-high endstop for high end on Y via pin !ystop
M574 Z1 S3 ; configure sensorless endstop for low end on Z; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X30:215 Y30:195 S20 ; define mesh grid; Heaters
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on set initial tool 0 active and standby temperatures to 0C; Tools
M563 P0 S"Flexion" D0 H1 F0 ; define tool 0
M501 ; load saved parameters from non-volatile memory -
Board: Duet 2 WiFi (2WiFi)
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.2.2 (2021-02-11)
Duet WiFi Server Version: 1.25 -
If the board is resetting it sounds like there may be a short in your wiring. Double check everything.
@Phaedrux my last hope is code. I unwire all connections except heat bed and nozzle, double check at the power source and reset behaviour persists
Can you send M122 after the board has reset and post the results here?
The printer was connected to a nobreak. I changed to a direct socket and...
it works! Thanks
What's a nobreak?
Nobreak = Computer Uninterruptible Power Supplies (UPS)
I understand now. That makes sense. They aren't typically rated to handle heater loads.
