No Axis Movement
Done. Homing moves X and Y - no Z. Here is M122: Q5 Send code... Status Idle Mode: FFF Tool Position X 0.0 Y 0.0 Z 210.00 Extruder Drives Drive 0 0.0 Speeds Requested Speed 0 mm/s Top Speed 0 mm/s Sensors Vin 24.2 V MCU Temperature 32.8 C Tools Extra Control All Tool Heater Current Active Standby Tool 0 T0 - Load Filament Heater 1 off 20.7 C 0 0 Bed Heater 0 off 20.9 C 0 0 Temperature Chart M122 9/16/2020, 11:12:11 AM M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later Board ID: 08DGM-956GU-DJMSN-6JTDA-3S46Q-TUQHH Used output buffers: 3 of 24 (11 max) === RTOS === Static ram: 27980 Dynamic ram: 92916 of which 56 recycled Exception stack ram used: 264 Never used ram: 9856 Tasks: NETWORK(ready,292) HEAT(blocked,1224) MAIN(running,1824) IDLE(ready,80) Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:01:41 ago, cause: software Last software reset at 2020-09-16 11:10, reason: User, spinning module GCodes, available RAM 9624 bytes (slot 2) Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN Error status: 0 MCU temperature: min 31.2, current 32.7, max 33.0 Supply voltage: min 24.1, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: standstill, SG min/max not available Driver 1: standstill, SG min/max not available Driver 2: standstill, SG min/max not available Driver 3: standstill, SG min/max not available Driver 4: standstill, SG min/max not available Date/time: 2020-09-16 11:12:09 Cache data hit count 168900657 Slowest loop: 2.20ms; fastest: 0.13ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 1.3ms, write time 0.0ms, max retries 0 === Move === Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms Bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 15.75ms; fastest: 0.00ms Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.23 WiFi MAC address 5c:cf:7f:76:71:a9 WiFi Vcc 3.29, reset reason Unknown WiFi flash size 4194304, free heap 24616 WiFi IP address 192.168.1.54 WiFi signal strength -48dBm, reconnections 0, sleep mode modem Socket states: 0 0 0 0 0 0 0 0 9/16/2020, 11:11:59 AM M115 FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-05-19b2 9/16/2020, 11:10:38 AM Connection established 9/16/2020, 11:10:36 AM Connection interrupted, attempting to reconnect... 9/16/2020, 11:10:28 AM G28 Error: G0/G1: insufficient axes homed 9/16/2020, 11:10:28 AM Emergency stop, attemping to reconnect... 9/16/2020, 11:10:11 AM Connection established 9/16/2020, 11:08:50 AM Connection interrupted, attempting to reconnect... HTTP request timed out 9/16/2020, 11:08:37 AM Upload of config.g successful after 1s 9/16/2020, 10:48:26 AM M115 FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-05-19b2 9/16/2020, 10:06:42 AM G28 Error: Failed to enable endstops 9/16/2020, 10:00:42 AM G28 Error: Failed to enable endstops 9/16/2020, 10:00:05 AM Connection established 9/16/2020, 10:00:04 AM Connection interrupted, attempting to reconnect... HTTP request timed out 9/16/2020, 9:59:44 AM Upload of config.g successful after 1s 9/16/2020, 9:59:12 AM G28 Error: Failed to enable endstops 9/16/2020, 9:59:02 AM Connection established 9/16/2020, 9:59:02 AM Connection interrupted, attempting to reconnect... HTTP request timed out 9/16/2020, 9:58:49 AM Upload of config.g successful after 1s 9/16/2020, 9:57:32 AM G28 Error: Failed to enable endstops 9/16/2020, 9:56:58 AM Connection established 9/16/2020, 9:56:58 AM Connection interrupted, attempting to reconnect... HTTP request timed out 9/16/2020, 9:56:18 AM Upload of config.g successful after 1s 9/16/2020, 9:38:32 AM Connected to 192.168.1.54
code_text
@1d1 Does your config.g have
M584 X0 Y1 Z4 E3
in it now? And you'll need to reset after changing this.Is your homedelta.g unchanged from the one you posted earlier in the thread?
Please sendM98 P"config.g"
and post the response (this checks for errors in config.g).Ian
@droftarts said in [No Axis Movement](/post/179087): > M584 X0 Y1 Z4 E3 Yes it is ; homedelta.g ; called to home all towers on a delta printer ; ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 16 2020 09:55:20 GMT-0400 (Eastern Daylight Time) G91 ; relative positioning G1 H1 X215 Y215 Z215 F1800 ; move all towers to the high end stopping at the endstops (first pass) G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass) G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred G90 ; absolute positioning G1 X0 Y0 F6000 ; move X+Y to the centre M98 P"config.g" HTTP is enabled on port 80 FTP is disabled TELNET is disabled Error: Invalid Z probe type 4 Error: Invalid Z probe index Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
@1d1 Change
M558 P4 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
to
M558 P5 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
(Probe type 4 is not supported in RRF3, use either 5 or 8.)
Still not sure why it's not activating the endstops. What EXACTLY happens when you press HOME ALL? If the X and Y motors are moving (the Z may not be, but I think that's possibly a wiring issue), how far do they move? They should move 215mm up towards the endstops. If they don't move that far (which may be why the endstops are not being triggered and you get the error message) it's possible that your steps per mm on XY and Z are incorrect.
Well, until I can get some homing done, I haven't even configured or connected my z probe. Or done a PID tune for the hot end either.
What happens right now is that X and Y push the extruder up and out between the X and Y towers. Z doesn't move at all. I hit emergency stop. If the Z went up, it would center the movement. I'll check the Z connections.
Z motor works fine when driven from another driver (X) so the wiring is good. Right now, I think that the endstops not working despite clear triggering when manually pushed. They just don't stop the motors, and end up banging away at the endstop switches. I need to look at the board while this is happening to see if they are actually being hit.
Everything worked perfectly on the MKS Base board that the printer shipped with. However, I wanted the Duet as I use a direct drive extruder and Duets on my other two printers.
I go do some more checks and see if I get any farther. -
@1d1 said in No Axis Movement:
i am confused
i dont think there is anything in the config.g you posted that would create this output.did you post the correct output?
I found it.. finally.... and terribly embarrassing: X and W were reversed at the drivers. It is now homing perfectly. Now I'm going to work on the Z probe setup and will introduce a new topic if I can't get it right. For now, and to all of you who helped, Major Thanks!!! I was lost and have now been found...
Oh - and PID tune too. It will be fine ... or else.
