Thermistors not recognized, open circuit temperature at 2000°C
So I have edited the config.g to state;
M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
M305 P0 ; Configure PT1000 for heater 0
M305 P1 ; Configure PT1000 for heater 1
M143 H1 S280 ; Set temperature limit for heater 1 to 280CUsing the G Code Console to send M305 P0 and M305 P1 to the machine and it replied with these settings
1:58:45 PMM305 P0
Heater 0 uses Thermistor sensor channel 0, T:362000.0 B:3950.0 C:0.00e+0 R:4700.0
1:58:18 PMM305 P1
Heater 1 uses Thermistor sensor channel 1, T:110000.0 B:3950.0 C:0.00e+0 R:4700.0As I am only testing it and trying to get it ambient temperature the PT1000's are currently free in mid air in an attempt to prevent shorts against the metal work.
that indicates that you are configuring your thermistors elsewhere.
check all files in the sys folder. especially config overwrite for any m305 commands.
@Scally123, you misunderstood me. When I said:
@dc42 said in Thermistors not recognized, open circuit temperature at 2000°C:
Try sending M305 P0 with no other parameters, and check it reports that it is configured for a PT1000. Likewise M305 P1.
I meant you to leave the M305 commands in config.g alone, but to run those 2 commands from the console, to check that the 2 heaters were configured to use PT1000 sensors.
