Endstop issues
@infiniteloop
Connected as per your instruction = 0.2V with or without magnet -
@tecno said in Endstop issues:
Just a note PWM out was easiest way to get power so it is needed
I wouldn't trust a PWM signal to be always high. Festo and their suppliers do not provide application notes, but this thing should be, at the bottom, a simple reed switch, which I suppose to work fine with 5V, too.
@nightowl999
Way too big for my taste, and yes I have tried.
@nightowl999
Just about every kind of inductive sensor you might need. This is the source I use.
@fcwilt
I know about them but way too expensive to get parts to Sweden. -
@fcwilt
I know about them but way too expensive to get parts to Sweden.My bad - didn't know you were in Sweden.
No worries Frederick
Problem solved !
Micro switches on each tower now.
This post is deleted! -
@arnold_r_clark said in Endstop issues:
On my Delta i use These
I use them for Z probes but never thought of using them for endstops.
To date I have used micro-switches or IR beam-break detectors.
Thanks for sharing another approach.
