M584 help needed
Can you also send M122 and copy and paste the result?
@jlee73 said in M584 help needed:
@phaedrux I meant x moves when I try to move y sorry
Did you experiment with the X and Y values in M669?
@phaedrux After doing some more reading I think I’ve got it set up wrong on the M669 code. It should be M669K0. Will try that tomorrow
Knnn Kinematics type: 0 = Cartesian, 1 = CoreXY,
So it's cartesian, and not corexy?
@phaedrux it has to be. K1 would most likely tell the motors on x&y to move at the same time right? But a K0 would allow the x&y motors to move independently correct?
What does the belt path for the printer look like? Can you show a photo?
This is what a corexy belt setup looks like.
@phaedrux Yeah that’s not it at all
This post is deleted! -
That is cartesian.
@phaedrux tomorrow when I get back there I will change it to you M669K0
@phaedrux That was the entire problem I just got back to the office changed it to him 669K0 and it completely solve the problem thanks for everyone’s help
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
